Go to Post These teams aren't elitists, but they sure are elite. - [more]
Unread 02-14-2010, 08:26 PM
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
Pneumatics Code
Hi everyone,
Last year our team didn't use any pneumatics on our robot so I never learned the code used in Wind River for to activate the compressor, regulators, etc. Could anyone provide me with a quick synopsis about how to program these features in C++ or just show me some source code for pneumatics that you have used? Thanks so much for the help.
Unread 02-14-2010, 08:33 PM
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
Team Role: Leadership
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: Pneumatics Code
This is Team 2502's Pneumatics code.
http://github.com/keehun/TeamRobotCo...Pneumatics.cpp
It's somewhat complicated but that's because we have it multithreaded and the kicker is programmed to automatically retract after half a second.
Otherwise, the constructor section is probably the most important. If you want a clear cut simple example, let me know!
Thanks,
Keehun
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 02-14-2010, 08:58 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: Pneumatics Code
read http://first.wpi.edu/Images/CMS/Firs...sers_Guide.pdf
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 02-14-2010, 09:36 PM
kennypu kennypu is offline
FRC #2467
kennypu is an unknown quantity at this point
Re: Pneumatics Code
I'm having problems with the compressor as well. I have the coding down, however I am not sure if the pwms are connected in the right direction. Is the ground (the black cable, for a regular white,red,black pwm) suppose to face in towards the sidecar or outtowards the edges? Also, I could not find the pin specs for the relay either, which pin is ground, +12, etc.?
EDIT:
okay I'm not sure whats wrong with ours. The compressor is functional, we have tested it with the battery. The relay is plugged into the relay port 1, and the pressure switch is on digital IO 1, both of the ground pins are facing out.
For the code,
I initialize the compressor using Compressor *m_com; at the beginning of the class, and declare it in the constructor: m_com = new Compressor(1,1); I do m_com->Start(); on the next line. This should start the compressor correct? It shows no activity for some reason.
Unread 02-15-2010, 12:17 PM
FRC #2589
Re: Pneumatics Code
great thanks for the help guys
Unread 02-15-2010, 07:29 PM
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Re: Pneumatics Code
Thanks,
Keehun
Dude, omg. Thanks so much. Saved us a ton of time and problems.
Pneumatics Testing...with code or direct to power? rsegrest Pneumatics 2 02-03-2010 04:40 PM
Pneumatics Code nighterfighter C/C++ 16 10-12-2009 05:52 PM
problems using gyro/adc code with camera default code tanstaafl Programming 7 01-22-2006 11:09 PM
Pneumatics-Code [and piston output length] reilly Programming 5 02-13-2005 11:42 AM
Pneumatics-Code [and piston output length] reilly Technical Discussion 0 02-10-2005 12:21 PM
