Thread Tools |
Rating:
Display Modes |
NetBeans Java Debugger Connects once, but not again
On 2 different computers, when I first installed NetBeans, I was able to run and debug one of the sample programs.
But after that first success, I haven't been able to do it again. This is the output I get, starting with what looks like some successful messages from constructors and whatnot. (i have a breakpoint set in the constructor that seems to be printing the "Iterative Robot ConstructorStart" message): [cRIO] FPGA Hardware GUID: 0xad9a5591cc64e4df756d77d1b57a549e [cRIO] FPGA Software GUID: 0xad9a5591cc64e4df756d77d1b57a549e [cRIO] IterativeRobot Constructor Start [cRIO] IterativeRobot Constructor Finish Waiting for connection from debugger on serversocket://:2900 Synchronizing debug state with VM............... Established connection to Debugger (handshake took 8376ms) [cRIO] !!! no thread found waiting on event=== DEAD-LOCK STATUS: === [cRIO] --- isolate 2 "edu.wpi.first.wpilibj.samples.CircleTrackerDe mo" (ALIVE) status --- [cRIO] thread Thread-10 priority: 5 state: ALIVE queue: RUNNABLE [cRIO] at com.sun.squawk.VMThread.monitorWait(VMThread.java: 2298) [cRIO] at java.lang.Object.wait(Object.java:162) [cRIO] at java.util.TimerThread.mainLoop(Timer.java:439) [cRIO] at java.util.TimerThread.run(Timer.java:391) [cRIO] at com.sun.squawk.VMThread.callRun(VMThread.java:1499 ) [cRIO] at com.sun.squawk.VM.callRun(VM.java:305) [cRIO] thread Thread-9 priority: 5 state: ALIVE queue: RUNNABLE [cRIO] at com.sun.squawk.VMThread.monitorWait(VMThread.java: 2298) [cRIO] at java.lang.Object.wait(Object.java:162) [cRIO] at java.util.TimerThread.mainLoop(Timer.java:439) [cRIO] at java.util.TimerThread.run(Timer.java:391) [cRIO] at com.sun.squawk.VMThread.callRun(VMThread.java:1499 ) [cRIO] at com.sun.squawk.VM.callRun(VM.java:305) [cRIO] thread FRCDriverStation priority: 5 state: ALIVE queue: RUNNABLE [cRIO] at com.sun.squawk.VMThread.waitForEvent(VMThread.java :1863) [cRIO] at com.sun.squawk.NativeUnsafe.waitForBlockingFunctio n(NativeUnsafe.java:641) [cRIO] at com.sun.cldc.jna.BlockingFunction.call2(BlockingFu nction.java:113) [cRIO] at com.sun.cldc.jna.Function.call2(Function.java:271) [cRIO] in static method #1 of edu.wpi.first.wpilibj.communication.FRCControl(bci =15) [cRIO] in virtual method #12 of edu.wpi.first.wpilibj.DriverStation(bci=10) [cRIO] in virtual method #11 of edu.wpi.first.wpilibj.DriverStation(bci=9) [cRIO] in static method #2 of edu.wpi.first.wpilibj.DriverStation(bci=5) [cRIO] at edu.wpi.first.wpilibj.DriverStation$DriverStationT ask.run(bci=6) [cRIO] at java.lang.Thread.run(Thread.java:231) [cRIO] at com.sun.squawk.VMThread.callRun(VMThread.java:1499 ) [cRIO] at com.sun.squawk.VM.callRun(VM.java:305) [cRIO] thread edu.wpi.first.wpilibj.samples.CircleTrackerDemo - main priority: 5 state: ALIVE queue: RUNNABLE [cRIO] at com.sun.squawk.VMThread.monitorWait(VMThread.java: 2298) [cRIO] at java.lang.Object.wait(Object.java:162) [cRIO] at java.lang.Object.wait(Object.java:257) [cRIO] at com.sun.squawk.debugger.EventNotifier.produceEvent (EventNotifier.java:122) [cRIO] at com.sun.squawk.debugger.EventManager.produceEvent( EventManager.java:184) [cRIO] at com.sun.squawk.debugger.sda.SDA.notifyEvent(SDA.ja va:1044) [cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(MIDletMa inWrapper.java:104) [cRIO] at com.sun.squawk.Klass.main(Klass.java:2997) [cRIO] at com.sun.squawk.Isolate.run(Isolate.java:1554) [cRIO] at java.lang.Thread.run(Thread.java:231) [cRIO] at com.sun.squawk.VMThread.callRun(VMThread.java:1499 ) [cRIO] at com.sun.squawk.VM.callRun(VM.java:305) [cRIO] --- isolate 1 "com.sun.squawk.debugger.sda.SDA" (ALIVE) status --- [cRIO] thread EventManager priority: 5 state: ALIVE queue: CONDVAR waiting on condvar for object com.sun.squawk.debugger.EventNotifier@10 [cRIO] at com.sun.squawk.VMThread.monitorWait(VMThread.java: 2298) [cRIO] at java.lang.Object.wait(Object.java:162) [cRIO] at java.lang.Object.wait(Object.java:257) [cRIO] at com.sun.squawk.debugger.EventNotifier.consumeEvent (EventNotifier.java:156) [cRIO] at com.sun.squawk.debugger.EventManager.run(EventMana ger.java:65) [cRIO] at com.sun.squawk.debugger.sda.SDA$SDAEventManager.ru n(SDA.java:608) [cRIO] at java.lang.Thread.run(Thread.java:231) [cRIO] at com.sun.squawk.VMThread.callRun(VMThread.java:1499 ) [cRIO] at com.sun.squawk.VM.callRun(VM.java:305) [cRIO] thread SDPListener priority: 5 state: ALIVE queue: EVENT [cRIO] at com.sun.squawk.VMThread.waitForOSEvent(VMThread.ja va:1910) [cRIO] at com.sun.squawk.platform.posix.SystemEventsImpl.wai tForReadEvent(SystemEventsImpl.java:306) [cRIO] at com.sun.squawk.platform.posix.GCFSocketsImpl.readB uf(GCFSocketsImpl.java:303) [cRIO] at com.sun.squawk.platform.posix.GCFSocketsImpl.readB yte(GCFSocketsImpl.java:337) [cRIO] at com.sun.squawk.io.j2me.socket.PrivateInputStream.r ead(Protocol.java:356) [cRIO] at java.io.DataInputStream.read(DataInputStream.java: 91) [cRIO] at java.io.DataInputStream.readInt(DataInputStream.ja va:332) [cRIO] at com.sun.squawk.debugger.JDWPConnection.readPacket( JDWPConnection.java:192) [cRIO] at com.sun.squawk.debugger.JDWPListener.run(JDWPListe ner.java:122) [cRIO] at java.lang.Thread.run(Thread.java:231) [cRIO] at com.sun.squawk.VMThread.callRun(VMThread.java:1499 ) [cRIO] at com.sun.squawk.VM.callRun(VM.java:305) [cRIO] thread SDA priority: 5 state: ALIVE queue: JOIN [cRIO] at com.sun.squawk.VMThread.join(VMThread.java:484) [cRIO] at java.lang.Thread.join(Thread.java:323) [cRIO] at com.sun.squawk.debugger.sda.SDA.go(SDA.java:1381) [cRIO] at com.sun.squawk.debugger.sda.SDA.main(SDA.java:1441 ) [cRIO] at com.sun.squawk.Klass.main(Klass.java:2997) [cRIO] at com.sun.squawk.Isolate.run(Isolate.java:1554) [cRIO] at java.lang.Thread.run(Thread.java:231) [cRIO] at com.sun.squawk.VMThread.callRun(VMThread.java:1499 ) [cRIO] at com.sun.squawk.VM.callRun(VM.java:305) [cRIO] --- isolate 0 "com.sun.squawk.JavaApplicationManager" (ALIVE) status --- [cRIO] thread IOHandler priority: 5 state: ALIVE queue: CONDVAR waiting on condvar for object com.sun.squawk.platform.posix.SystemEventsImpl@11 [cRIO] at com.sun.squawk.VM.reifyStack(VM.java:1029) [cRIO] at com.sun.squawk.VMThread.printStackTrace(VMThread.j ava:1752) [cRIO] at com.sun.squawk.Isolate.printAllThreadStates(Isolat e.java:2696) [cRIO] at com.sun.squawk.Isolate.printAllIsolateStates(Isola te.java:2712) [cRIO] at com.sun.squawk.VMThread.rescheduleNext(VMThread.ja va:1606) [cRIO] at com.sun.squawk.VMThread.reschedule(VMThread.java:1 781) [cRIO] at com.sun.squawk.VMThread.monitorWait(VMThread.java: 2298) [cRIO] at java.lang.Object.wait(Object.java:162) [cRIO] at com.sun.squawk.platform.posix.SystemEventsImpl.wai tForEvents(SystemEventsImpl.java:223) [cRIO] at com.sun.squawk.platform.SystemEvents.run(SystemEve nts.java:71) [cRIO] at java.lang.Thread.run(Thread.java:231) [cRIO] at com.sun.squawk.VMThread.callRun(VMThread.java:1499 ) [cRIO] at com.sun.squawk.VM.callRun(VM.java:305) [cRIO] thread primitve-thread priority: 5 state: ALIVE queue: ISOLATEJOIN [cRIO] at com.sun.squawk.VMThread.isolateJoin(VMThread.java: 504) [cRIO] at com.sun.squawk.Isolate.join(Isolate.java:1575) [cRIO] at com.sun.squawk.JavaApplicationManager.main(JavaApp licationManager.java:150) [cRIO] at com.sun.squawk.Klass.main(Klass.java:2997) [cRIO] at com.sun.squawk.Isolate.run(Isolate.java:1554) [cRIO] at java.lang.Thread.run(Thread.java:231) [cRIO] at com.sun.squawk.VMThread.callRun(VMThread.java:1499 ) [cRIO] at com.sun.squawk.VM.callRun(VM.java:305) none of the debug buttons, such as step or pause or go are enabled. Suggestions anyone? Thanks much. |
| Netbeans/Overall Java/Code help!!! | a kenny03 | Java | 5 | 18-01-2010 22:32 |
| Please once again help us | 1166 | Electrical | 3 | 03-02-2004 22:04 |
| Approaching Pneumatics..once again | archiver | 2000 | 2 | 24-06-2002 00:38 |
| Once again offering problems, but no solutions | archiver | 2000 | 1 | 23-06-2002 22:53 |
| GMCIA - It's time once again... | archiver | 2001 | 2 | 23-06-2002 22:35 |
