Re: Limit Switch Draws Tears
Originally Posted by gokul
...Make sure your switch itself is a normally Open type switch Switches come as Normally Open and Normally Closed - closed will always show one unless it is operated in a different way...
Not true. "Normally" only reflects the position of the contacts when the switch is not pressed. A NO switch will close when pressed, a NC switch will open.
There are many times when you want a NC switch. This is particularly true of limit switches. If a wire breaks and the switch is no longer "in the circuit" you want the motor or actuator that you are limiting to stop. This is usually much safer...
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
