Go to Post Hard work is a necessary prerequisite for luck. - Ian Curtis [more]
Unread 15-02-2010, 11:01
DynamiteHack DynamiteHack is offline
FRC #2988
DynamiteHack is an unknown quantity at this point
Changing gearing
Our team has been working on a kicker which uses a CIM motor connected to a toughbox. Upon completion, we found that it wasn't spinning fast enough to kick the ball more than 5 feet or so. Unfortunately, the toughbox uses a different shaft for the drive gear than for the others, so it isn't just a matter of swapping gears.
My question is, is there a way to change the gearing in a toughbox? Specifically, is there a hex-shaft available which will fit over the motor shaft in order to make the other gears fit on it?
Gearing Up! (FIRST documentary) gearingup General Forum 59 30-10-2013 03:19
DC Motor and Gearing Red-Rx7 Motors 18 22-03-2008 16:35
Gearing Ratios satyam Motors 1 31-01-2004 09:50
Gearing Calculator Gui Cavalcanti Technical Discussion 6 09-08-2002 10:06
Gearing down? nerdy Technical Discussion 2 14-01-2002 00:15
