Go to Post The question is like asking "Is it better to drive by looking at a map the whole time or by remembering where you want to go and watching the road instead?" - lukevanoort [more]
Unread 02-15-2010, 11:40 AM
abpahl abpahl is offline
FRC #3407
abpahl is an unknown quantity at this point
Very basic programming issue
First of all, I know almost nothing of programming. We spent a lot of time on debugging and troubleshooting, and I'm just now getting around to writing the code. I have a tiny issue that I don't know how to fix.
I'm building my code off the sample template, and having almost no C++ knowledge, I'm working completely off example.
My currently modified( not by much, just added a third motor) code is as follows:
Code:
#include "WPILib.h"
#include "vision/AxisCamera2010.h"
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system
	Joystick stick;// only joystick
	Jaguar kicker; // call kicking motor
public:
	RobotDemo(void):
		myRobot(1, 2),	// these must be initialized in the same order
		stick(1),
		kicker(3)// the motor for kicking should be plugged into slot 3
		// as they are declared above.
		GetWatchdog().SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous(void)
		// I edited this code for testing
		GetWatchdog().SetEnabled(false);
		myRobot.Drive(0.5, 0.0); 	// drive backwards half speed
		Wait(1.0);
		myRobot.Drive(0.0,0.0);//    stop for a bit
		Wait(1.0);
		myRobot.Drive(-5.0, 0.0);// go back to where you started
		Wait(1.0);
	 * Runs the motors with arcade steering.
	void OperatorControl(void)
		GetWatchdog().SetEnabled(true);
		while (IsOperatorControl())
			GetWatchdog().Feed();
			myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
			if  (stick.GetTrigger()) // use trigger to activate kicking device (I added this bit)
				kicker.Set(1.0); // If trigger is pressed, full speed!
			else
				kicker.Set(.2); // Otherwise, go at 1/5 speed
			Wait(0.005);				// wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
The issue is that the joystick is currently reversed. Forward and backwards are fine, but if you go left on the joystick, the robot goes right, and vice versa. Switching the PWM slots on the jaguars doesn't help, it just inverts forward and backwards. It seems like this would be very easy to fix, but I have no clue where to start.
Do I need to modify RobotDrive? And if so, where do I modify it? If I modify a file in WPIlib, will the new file get built into my project?
Unread 02-15-2010, 11:55 AM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Re: Very basic programming issue
Here's my take:
Set your PWM cables such that you get the following behaviour:
Forward and Backwards are reversed
Left and Right are reversed
Hopefully when you do this, you'll notice that PWM 1 -> Left and PWM 2 -> Right, just as it should be based on what your code says.
Power down the robot, and on ALL your drivetrain speed controllers, switch the red and black wires that lead to the motors. That will reverse their direction.
Other here might recommend extensive coding changes to make this change in programming, but seeing as how you'd said your programming expertise is low, I think this is your best fix! Just make sure you document that you flipped these wires so that the next person who hooks up your motors knows to reverse them.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 02-15-2010, 12:05 PM
FRC #3407
Thanks, that is exactly what was needed!
Unread 02-15-2010, 11:41 PM
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Actually, to fix it just add a - before the GetAxis on the joyticks and it will run the motors in the opposite directions. The joyticks are very un-intuitive and have forward as a negative value. In case you're wondering, the - simply does a mathematical negative on the value
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 02-16-2010, 03:56 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
however, he is using the compressed form:
not
myRobot.ArcadeDrive(stick.GetY(), stick.GetX());
so your suggestion won't work (at least at this point)
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Very Basic: Get a program running on the cRio that will show video on Classmat isaacdl Control System 6 01-23-2010 05:33 PM
very basic code help mikelowry C/C++ 20 09-18-2009 06:38 PM
Very odd issue with WindRiver GGCO C/C++ 1 01-24-2009 01:21 AM
BASIC programming John Gutmann Programming 3 05-17-2005 12:15 PM
Very Basic Programming Question kewlkid382 Chit-Chat 5 01-18-2003 11:11 AM
