Magnetic Reed Switch
Hey, I wanted to know how to include a magnetic reed switch for one of our pistons in our program, if programming it is actually needed. I saw on one of the threads that the reed switch is plugged in to a digital IO slot on the digital sidecar, but is that all that needs to be done or do you have to program it? If so would someone be able to post on how to do it. Thanks
Re: Magnetic Reed Switch
You do have to program it.
You use the Digital Input palette found under WPI Robotics Library -> IO -> DigitalInput Add a DIO Open to Begin.vi Add a DIO Close to Finish.vi Add a DIO Get to Teleop.vi and do whatever you want with the information. Last edited by Mark McLeod : 15-02-2010 at 21:56. |
Ohh ok thanks for the help Mark, greatly appreciated
| Magnetic Reed Switches... | Transformers | Pneumatics | 5 | 17-02-2007 01:12 |
| Magnetic Reed Switches and cylinder boom positions???? | cdennisxlx2 | Pneumatics | 7 | 11-07-2006 21:17 |
| Magnetic Reed Switches (need help) | cdennisxlx2 | Pneumatics | 1 | 03-02-2006 06:47 |
| is the reed switch legal? | Anne Lam | Technical Discussion | 3 | 14-02-2002 12:39 |
