Go to Post To me, as a student, it doesn't really matter how old the RoboCoach is. My only concern is that they don't get ape-crazy when the game starts. - AZNkommander [more]
Unread 15-02-2010, 13:30
z.s.tar.gz z.s.tar.gz is offline
FRC #3242
z.s.tar.gz is an unknown quantity at this point
How to configure the cRIO with windriver?
How exactly do you set up the cRIO with windriver? I followed the guide in /docs/frc and I did some googling, but the cRIO still won't connect.
I've heard that I need to reimage the device, how exactly would I do that?
Unread 15-02-2010, 18:45
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: How to configure the cRIO with windriver?
did you look on this page: http://usfirst.org/roboticsprograms/....aspx?id=10934
the one you need is section 2.6 (page 31) of http://usfirst.org/uploadedFiles/Com...ed-Rev-0.7.pdf
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 16-02-2010, 20:12
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
Team Role: Leadership
Rookie Year: 2007
whatabouteve is an unknown quantity at this point
You must use the labview Imaging device.
You set it to windriver C++ when you use it. This is how we did it. It is a completely different thing from labview.
Unread 17-02-2010, 08:50
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
Rookie Year: 2007
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
This confused our team at first as well... we wondered what LabVIEW had to do with setting up the robot for C++. However, the imaging program is installed (and updated) with LabVIEW. When you run it, just set it to C++ development.
On that note, there's a new cRIO image out (vesion 20). Make sure you image your robot with that and not the old version 19. To get it, download and run the newest LabVIEW update.
How to connect the Workbench with the cRIO? kentschool C/C++ 3 28-12-2009 16:03
How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes brreadd Pneumatics 3 20-11-2009 15:35
Windriver connection to cRio avolkov Programming 6 05-05-2009 08:40
Running the Motors Backward in WindRiver & cRIO Freezes kyungjin C/C++ 15 08-02-2009 14:24
CRIO not working with Windriver dpeterson3 C/C++ 7 07-01-2009 20:49
