Go to Post You can never take enough precautions when it comes to safety. Please, be prepared for anything. - Tom Bottiglieri [more]
Unread 15-02-2010, 14:17
daniel_3158 daniel_3158 is offline
FRC #3158
daniel_3158 is an unknown quantity at this point
Cool Deploying Code??
Hi I have a doubt about how to deploy a code an run it as start up in the CompactRio?? I have done it several times but still theres no robot code indicator in the DS.
Thanks!
Code:
Unread 15-02-2010, 14:20
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Deploying Code??
What Language?
In LabVIEW, you right-click on the FRC Boot-Up Deployment, click Build, wait for it to build, then right click on it again and click Run As Startup. When it finishes, it will ask you to reboot, say yes. When it reboots, you will see Communication in the Driver Station but not Robot Code, Robot Code will take another 10-30 seconds. Be patient, the entire boot-up does take some time.
Kettering Motorsports
Unread 15-02-2010, 16:49
FRC #3158
Thanks
Code:
Code Deploying Problems[Java] Cjdowney Programming 2 16-02-2010 18:06
Need Help With Deploying Code Darth Pbal National Instruments LabVIEW and Data Acquisition 2 02-02-2010 19:20
Issue deploying Code rudun Java 5 18-01-2010 21:24
LabVIEW code deploying instead of running linkhyrule5 NI LabVIEW 6 10-01-2010 14:57
Problem deploying/running default code blaxbb FRC Control System 0 10-01-2009 11:59
