Go to Post A true form of GP would be to send out a congratulations to all the teams that made it, regardless of whether or not you think they should have. - Molten [more]
Unread 15-02-2010, 15:23
Alexandstein Alexandstein is offline
FRC #2192 (YAK Attack)
Rookie Year: 2007
Alexandstein is an unknown quantity at this point
Solenoid actuation problems
We are using pneumatics for our kicker this year as many are, but we are having problems actuating the pneumatics.
Every time an actuation command is given, nothing actuated. The lights on the solenoid light up when the commands are given, so the signal seems to be getting through.
Manual actuation works fine, so nothing is wrong with the actual valves.
Thanks!
Solenoid not firing off Solenoid Breakout spooncwru Pneumatics 2 30-01-2010 17:46
Elevator Actuation Sprocket is Slipping JesseK Technical Discussion 6 17-02-2008 09:45
pic: pneumatic actuation of ball valve Andrew Schuetze Extra Discussion 2 30-10-2006 08:40
Building fully flexible tail (several joints) with minimal actuation required sanddrag Technical Discussion 51 27-11-2005 18:05
Mechanical actuation kbrown Pneumatics 1 17-02-2004 16:09
