Go to Post Speculate away! - IndySam [more]
Unread 15-02-2010, 17:23
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Rookie Year: 2007
Team1710 is an unknown quantity at this point
Limit switches to Jaguars
Can I connect a limit switch directly to the Jaguar through the jumper port? Is this allowed according to rule R63B and R60L?
Unread 15-02-2010, 17:25
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Limit switches to Jaguars
<R60-L> has the answer. A limit switch sensor would count as a custom limit switch circuit...
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 15-02-2010, 18:46
Team1710's Avatar
FRC #1710
Rookie Year: 2007
<R60.L> says if the CAN-bus functionality is used. If we are using a PWM cable to connect the Jaguar to the Digital Sidecar are we then unable to connect the limit switch directly to the Jaguar?
Just want to clarify, thank you.
Unread 15-02-2010, 18:54
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Correct to the best of my knowledge.
Past teams:
Unread 15-02-2010, 19:09
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
From R60
L. If CAN-bus functionality is used, limit switch jumpers may be removed from a Jaguar speed controller and a custom limit switch circuit may be substituted (so that the cRIO-FRC may read the status of the limit switches).
You may use limit switches by connecting through the Digital I/O. The processing path is pretty much the same.
Al
WB9UVJ
www.wildstang.org
________________________
Limit on number of Jaguars? Joe6391 Electrical 5 03-02-2010 23:19
Limit Switches Wicked NI LabVIEW 9 04-03-2009 17:21
Limit Switches popnbrown NI LabVIEW 1 10-02-2009 22:39
limit switches stephenthe1 Programming 28 11-05-2005 16:37
Limit switches Team168 Programming 8 10-02-2003 16:22
