Go to Post Adding more weight doesn't make the challenge any easier, it just makes the robots heavier. - Sean Schuff [more]
Unread 02-15-2010, 05:47 PM
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
Question Programming the teleop
My programming team are stuck
like the title says I'm tying to program I don't know what I'm missing
code
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
public class Demonized extends SimpleRobot {
RobotDrive drive = new RobotDrive(1, 2);
Joystick leftStick = new Joystick(1);
Joystick rightStick = new Joystick(2);
Watchdog Fenrir = Watchdog.getInstance();
public void autonomous() {
while(true && isAutonomous() && isEnabled())
for (int i = 0; i < 4; i++) {
Fenrir.feed();
drive.drive(0.5, 0.0); // drive 50% fwd 0% turn
Fenrir.feed();
drive.drive(0.0, 0.5);
drive.drive(0.0, 0.0); // drive 0% fwd, 0% turn
public void operatorControl() {
while (true && isOperatorControl() && isEnabled()) // loop until change
drive.tankDrive(leftStick, rightStick);
Timer.delay(0.005);
Fenrir.feed();
help will be much appreciated
team 581
Enable Teleop in Robot Main ThisAintJeff NI LabVIEW 4 02-04-2010 02:33 PM
NXT Mindstorm Teleop EXamples johncap100 FIRST Tech Challenge 4 10-10-2009 09:48 AM
problem with passing doubles back into the "TeleOp Execute" loop windell747 NI LabVIEW 1 03-21-2009 12:50 AM
Teleop Lag Xavier Brandall Programming 14 03-17-2009 06:21 PM
Detecting Start of TeleOp Mode Danny Diaz Programming 4 02-26-2008 01:37 AM
