Go to Post All this community stuff is actually pretty fun! :) - JBotAlan [more]
Unread 17-02-2010, 19:22
Poke2201 Poke2201 is offline
AKA: Josh
FRC #0814
Rookie Year: 2010
Poke2201 is an unknown quantity at this point
Re: Coding Relay with Compressor
Alright, Looking around on here, there seems to be one thing I didn't notice. We cant get a RSL on. Both of our Sidecars do not have RSL leds on or doing anythign at all. Also 2 out of 3 power lights are on, the 6v and Bat are on, but 5v isnt.
Unread 17-02-2010, 19:53
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Disconnect everything from the digital sidecar (including the 37) pin cable, so that just the power cable is plugged in. If you still only have some of the power leds, there is a problem with the digital sidecar. If all power LEDs are on, add each cable one at a time and see which one causes the 5v power LED to go out.
solenoid with compressor vi ElanaC NI LabVIEW 42 29-12-2010 13:38
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
Help needed with coding simultaneous movement (EasyC/VEX) bodaciousllama Programming 7 14-08-2006 17:35
Problem with compressor Nick R. Pneumatics 3 21-02-2003 10:51
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
