Go to Post A year where the students learn a lot and win nothing is more rewarding than a year where the team does well and doesn't learn much. - Molten [more]
Unread 02-15-2010, 11:28 PM
kennypu kennypu is offline
FRC #2467
kennypu is an unknown quantity at this point
Compressor won't start
For some reason, our compressor won't start when the code deploys fine, and we have the compressor and pressure gauge switch hooked up correctly ( I think). The compressor should start soon as the robot is turned on correct? The compressor for us doesn't even start even if we enable teleops in the DS. Any help will be appreciated. I may be missing a simple step, so if anybody has an idea, please give suggestions. Here is the code btw:
Code:
#include "WPILib.h"
#include "Vision/AxisCamera2010.h"
#include "Vision/HSLImage.h"
#include "PIDController.h"
#include "Gyro.h"
#include "Target.h"
#include "DashboardDataSender.h"
//#define MINIMUM_SCORE 0.01
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
bool moveState = false;
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system
	Joystick stick; // only joystick
	Jaguar leftMotors;
	Jaguar rightMotors;
	Compressor compressor;
	Relay relay;
	//DashboardDataSender *dds;
	//Gyro *gyro;
	//PIDOutput *pidOutput;
public:
	RobotDemo(void):
		myRobot(3, 4),	// these must be initialized in the same order
		stick(1),		// as they are declared above.
		leftMotors(1),
		rightMotors(2),
		compressor(4,2)
		//start the compressor
		compressor.Start();
		AxisCamera &camera = AxisCamera::getInstance();
		//dds = new DashboardDataSender();
		//gyro = new Gyro(1);
		//pidOutput = new SamplePIDOutput(myRobot);
		GetWatchdog().SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous(void)
		GetWatchdog().SetEnabled(false);
		myRobot.Drive(0.5, 0.0); 	// drive forwards half speed
		Wait(2.0); 				//    for 2 seconds
		myRobot.Drive(0.0, 0.0); 	// stop robot
	 * Runs the motors with arcade steering.
	void OperatorControl(void)
		GetWatchdog().SetEnabled(true);
		while (IsOperatorControl())
			GetWatchdog().Feed();
			//myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
			if(stick.GetRawButton(1))
				moveState = 0;
			if(stick.GetRawButton(3))
				moveState = 1;
			if(moveState == false)
				//do nothing
			if(moveState == true)
				leftMotors.Set(-stick.GetY());
				rightMotors.Set(stick.GetZ());
				Wait(0.005);
			// Create and set up a camera instance. first wait for the camera to start
					// if the robot was just powered on. This gives the camera time to boot.
					//Wait(10.0);
					//printf("Getting camera instance\n");
START_ROBOT_CLASS(RobotDemo);
as you can see, its quite simple, however I don't know what is going on. Thanks again,
ken
Compressor won't start Alex_2487 C/C++ 6 02-12-2009 04:41 PM
Wind River won't start radau C/C++ 6 01-19-2009 11:09 PM
Won't Download! diaperrash89 Programming 4 10-25-2007 11:02 PM
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 02-06-2006 06:23 PM
Help! My 2003 Bot compressor won't shut off Jack21 Control System 10 02-11-2004 12:24 PM
