Go to Post Certainly more interesting to watch than driving around in circles on a flat field. Sorry, 2008. - synth3tk [more]
Unread 16-02-2010, 00:14
rjn rjn is offline
rjn is an unknown quantity at this point
Digital I/O problems
Currently our team is having issues with any sort of digital devices. Our digital side car has all of the lights lit, though the RSL light does a slow blink. We have switched out the module, cable, and dsc. None of which helped. We have ruled out code, we still recieve camera feed, we can still search for ellipses, etc.. We did check each of our digital side cars and each of the C6 capacitors were loose. It was only a few days ago that our electronics were working fine and dandy.
Possible courses of action?
Unread 16-02-2010, 00:58
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Digital I/O problems
Slow Blink usually means the robot is disabled. Does it change to on with a brief flicker off every second and a half when you Enable on the Driver Station?
Is it only the big panel light doing the Slow Blink, or does the little green LED by the RSL connector also do it simultaneously? The big panel light will blink by itself if jumper is not installed between its outer two pins.
Digital Sidecar Problems cabbagekid2 FRC Control System 13 31-01-2009 17:23
Digital IO in C++ EricGoodchild C/C++ 3 15-01-2009 23:05
Ultrasonic sensors on digital ports 3-6 problems wt200999 Programming 14 13-02-2008 08:13
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
