Go to Post The only tool that will work to get our robot done in time will be a prayer rug. - Rick TYler [more]
Unread 16-02-2010, 10:29
mama_tree's Avatar
mama_tree mama_tree is offline
FRC #3168 (WARRIORS)
Team Role: Teacher
mama_tree has a spectacular aura aboutmama_tree has a spectacular aura aboutmama_tree has a spectacular aura about
Failed to establish with VM
So, my kids have installed the updates and now... we are getting an error message stating "Failed to establish with VM" and that it will try again in 5 seconds. This happened right after it connected to the cRio. We did not have this problem before we installed the update.
On a side note- Our code worked before the updates- except the jaguars aren't working for some reason- it told us that the jaguars are getting the message but for some reason they are not activating the motors.
Any ideas?
Failed to Connect after reinstall Blooper4912 C/C++ 2 07-02-2009 13:04
Failed Benchtop test rhoads2234 Programming 22 10-01-2009 10:49
pic: 1625 Failed Lift Eldarion Extra Discussion 5 19-03-2007 00:58
Compiling Failed Teh Mike Programming 7 09-02-2005 13:27
pic: Failed attempt at simulation CD47-Bot Extra Discussion 5 17-06-2004 11:03
