Go to Post Gravity is not always pointing the same direction relative to the robot! - ChrisH [more]
Unread 16-02-2010, 13:54
wwrobotics1452 wwrobotics1452 is offline
FRC #1452
wwrobotics1452 is an unknown quantity at this point
Code not staying on the cRio
How do we get the code to stay on the cRio when we turn the driver station on and off?
Unread 16-02-2010, 14:14
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Code not staying on the cRio
What Language?
In LabVIEW, if you hit the "Play" button (Deploy), it just stores code in RAM. To get it to do a full build and deploy, go to your project, click the [+] next to "Build Specifications", then right-click on "FRC cRio Boot-up deployment", and click "Build". When it is done, right-click on boot-up deployment again and click "Run As Startup". When it is done, you will be good.
Kettering Motorsports
Unread 16-02-2010, 15:35
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Java, you just need to click the run button, and it should just work.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 16-02-2010, 15:47
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
I think you mean turn the robot on and off, the DS has no bearing on code staying put.
LabVIEW and Java are covered, so in Windriver, FIRST>Download after you have set the out file and your team number in Window>Preferences>First downloader prefs
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 16-02-2010, 16:09
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Duct Tape?
Sorry, just a bit of week 6 mentor insanity there
2016 Central Illinois Winner. Curie Division finalist
Unread 18-02-2010, 17:17
FRC #1452
Thanks. Problem solved!
@BJT-I wish it was that simple!
Code deploys but does not save to cRIO Bill Taylor NI LabVIEW 11 15-02-2012 20:30
Code Not Going to cRIO mgamman Java 3 15-02-2010 12:10
Downloading code: Netbeans does not reset cRIO ellisk Java 8 31-01-2010 19:02
cRIO Not Running Code?!? JohnFogarty Programming 11 17-01-2010 19:08
cRio keeps on staying red on the lab view connection test bio hazard Programming 1 14-02-2009 19:45
