Go to Post We did the best job we could out there, and unfortunatly we have human limits.. The refs don't catch every penalty, inspectors don't catch every issue, and this year the score keepers won't catch every single ball. - nobrakes8 [more]
Unread 16-02-2010, 15:57
nheft nheft is offline
FTC #0533 (Psichotics)
Rookie Year: 1999
nheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the rough
Losing Communications in Labview
Has anyone else seen this problem?
In the LabView environment we make a simple change, hit the run button from the Robot Main front panel or Robot Main block diagram and Labview chugs along up to the point where it has to start uploading the changes to the robot, then we get a pop-up that says communication with the target has been lost. This seems to happen regardless of whether we are connected with a crossover cable or using the wireless link. When it happens, we have to cancel the deployment, reboot the robot, and start again. After the reboot the new program sometimes deploys OK but sometimes it takes a second or even a third attempt before we get a normal deployment.
In addition, I notice that the robot does not always communicate with the DS on boot-up. The ethernet light stays solid on and does not flash on and off like it does during a normal boot-up.
I am presently running with the first "mandatory" update that came out in January (FRCLabVIEWUpdate2.0for2010.zip). I have not tried re-imaging the cRIO with the latest February 11 FRCLabVIEWUpdate2.1for2010.zip release.
Neil Heft
Team 533
HELP I'm Losing it! aka Labview deploy vs. run kngscrpn24 NI LabVIEW 12 20-02-2011 23:41
Losing Communication Chief Pride FRC Control System 15 29-07-2009 17:46
losing air pressure razor95kds Pneumatics 3 13-02-2007 07:17
pic: Losing stinks Joe_Widen Extra Discussion 1 27-05-2006 17:33
