Go to Post We had an autonomous bug last year . . . Funnily enough, this worked real well and other teams were asking us for this "feature." - dragoonex [more]
Unread 16-02-2010, 16:29
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
4 Motor Tank Drive Problem
So yesterday we encountered a problem with our tank drive program. Last year we used only 2 motors for driving last year, this year we are using 4 motors instead. In the default code i replaced the arcade drive with tank drive and added the close vi in finish. Everything worked fine on our past year robot with 2 motors but when i replaced the open 2 motor vi with an open 4 motor vi we had some issues. The robot drives with the open 4 motor but only 2 of the motors work, one from each side. We have a victor for each motor but only 2 of the victors are receiving signal. The robot is driving but only 2 of the motors are active we would like to get all of the motors working. If anyone has any ideas on how to fix this issue please post. Thanks
Unread 16-02-2010, 23:02
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: 4 Motor Tank Drive Problem
I will suggest two things. First, make absolutely certain that the PWM channels you're specifying in the Open 4 Motor are the ones connected to your speed controllers. Second, try reseating the PWM connectors in the Victors; they are notoriously difficult to get right without lots of practice.
Unread 21-02-2010, 13:44
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
Rookie Year: 2010
dotbran is on a distinguished road
Why would you need four motors for tank drive?
Unread 21-02-2010, 14:16
pSYeNCe's Avatar
pSYeNCe pSYeNCe is offline
Programaster
AKA: James
FRC #2010 (Lightning Bots)
Rookie Year: 2007
pSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to behold
Just for more power, I would imagine.
As for the actual problem, I agree that you should double check the PWMs in the program and check the physical connectors. We are using Jaguars for the same purpose without issue.
If your PWMs in the program are correct, I would think it's a hardware problem.
Unread 21-02-2010, 14:19
AKA: Brandon Olsen
FRC #3219 (TREAD)
Rookie Year: 2010
That makes sense.
In that case, how about just doing two instances of tank drive (one for front, one for back) and setting everything to control both in parallel?
Or, are you sharing each pair of motors with each pair (L/R) of wheels?
Unread 21-02-2010, 14:28
pSYeNCe's Avatar
Programaster
AKA: James
Rookie Year: 2007
Hmm, I don't see any reason why not. I'd say try that, and if that doesn't work and you're sure of the PWMs then you definitely have a hardware problem.
Unread 21-02-2010, 23:21
Software Architect
If the Open 4 Motor isn't working, two Open 2 Motors with the same four PWMs wouldn't open either.
That is the typical way to do it, with two motors on each gearbox.
Unread 22-02-2010, 22:33
Josh987's Avatar
Josh987 Josh987 is offline
That's what I say.
AKA: Josh
FRC #1565 (Think Tank Tech)
Josh987 is an unknown quantity at this point
Make sure you open the 4 motors in "begin" and that it is referenced properly in "teleop", "partial tasks", and "end" vi's. Also when running the code check on the drivers station to see if the PWM's are being sent a signal.
Charlieeeeee, Candy Mountain
Tank Drive vs. Omni Directional Drive jamie_1930 General Forum 9 24-01-2010 22:50
Problem with tank drive Mr. E NI LabVIEW 6 27-01-2009 16:59
Tank Drive Sauce Programming 1 05-01-2009 18:50
Tank Drive Idaman323 Programming 14 15-02-2005 09:01
tank drive Stormhammer Programming 11 29-01-2004 23:08
