Go to Post Maybe we can start a FIRST team on Mars. - Karibou [more]
Unread 16-02-2010, 18:19
WSP_SNIPER WSP_SNIPER is offline
VRC #3100
WSP_SNIPER is an unknown quantity at this point
AxisCamera not sending images
what the heck the camera will not send images
is this a problem with the code given to us cause there is many people with this problem and you dont have to do much with the camera to get it to work and i dont think i have anything wrong
ARRG!
code =
AxisCamera &camera;
MyRobot::MyRobot:
camera(AxisCamera::GetInstance())
// write camera stuff here
Unread 17-02-2010, 08:48
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
Rookie Year: 2007
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: AxisCamera not sending images
While a lot of people have this problem, it usually turns out to be a configuration issue. If it was a problem with the WPILib source, it woldn't work for anybody.
The first thing I'd do is make sure all my equipment is configured properly. Make sure the camera is set up properly to the correct IP (an incorrect one will not let you receive images from the camera). Also make sure the dashboard softare laptop is configured to the correct IP as well.
Unread 17-02-2010, 15:26
kennypu kennypu is offline
FRC #2467
kennypu is an unknown quantity at this point
the problem I had was that I was using a ethernet cable. Make sure you're using a crossover cable, they are different cables -.-
Axiscamera.h not found Josh987 C/C++ 4 23-01-2010 14:33
Camera not sending image to Classmate? TPNigl Programming 14 22-01-2010 17:05
C++ AxisCamera writeCompression Bryscus Programming 2 21-01-2010 15:48
Google Images Game (Not 56k Friendly) Chief Pride Games/Trivia 98 17-12-2008 20:59
Sending Data Raven_Writer Programming 8 11-09-2003 16:28
