Go to Post your bot brings all the boys to the yard. - looneylin [more]
Unread 16-02-2010, 18:24
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
quation about 10" mecanum wheels
Any team use for FRC 2010 10" mecanum wheels, I wonder who we can 2010 assembled them with FRC 2010 chasse, Mounting options with gear AM or Toughbox am-0145
Official 2010 FIRST Kit of Parts Gearbox is butter.
Any help???
TEAM 1946-Tamra
Unread 19-02-2010, 00:59
Imadapocalypse's Avatar
Imadapocalypse Imadapocalypse is offline
The Walking Contradiction
AKA: Bryce Ribucan
FRC #2443 (Blue Thunder)
Team Role: Leadership
Imadapocalypse is an unknown quantity at this point
Send a message via AIM to Imadapocalypse
Re: quation about 10" mecanum wheels
Any help???
We were able to assemble and mount the mechanum wheels to our base
a couple problems came up from this:
1. our wheels caused some of the brackets to bend
2. those bending brackets caused loosening chains
The needs of the many out-weigh the needs of the few and the one
Unread 19-02-2010, 09:33
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
I *think* what you're asking is if any team is using the 10" Mecanum wheels offered by AndyMark on their 2010 FRC robot. And if so, how to mount them with the 2010 KoP Chassis, and powering them with the Toughboxes.
(I realize you're from Israel and English is almost certainly not your first language. Perhaps try a different translation program next time?)
To answer what I think the question is: I doubt that many, if any, teams are using the 10" mecanums from AndyMark as they are 2 things that are rather problematic to FRC teams. They are expensive ($710/set), and they are heavy (steel: 14lbs/wheel! alum: 7lbs/wheel). I don't know of many robots that can afford 56lbs (or even 28lbs) in wheels alone. They're also way bigger than an FRC robot needs.
8" Mecanum wheels and KOP wheel brackets smcmahon Technical Discussion 9 30-01-2010 12:19
Questions about mecanum wheels lollypop2020 Programming 8 21-01-2010 23:30
AndyMark 10" Mecanum Wheels ChuckDickerson General Forum 7 31-12-2008 12:54
Bumpy Ride with AM's 8" Mecanum wheels? Leav Technical Discussion 12 14-02-2008 01:16
need help about Mecanum Wheels mahmosh Technical Discussion 4 18-01-2008 11:50
