Go to Post Would FIRST be as amazing if not for CD? I mean it would still be this amazing place for students and mentors to be but the explosion of innovation and gathering of people together across communities has to have been greatly effected by CD. - dodar [more]
Unread 02-16-2010, 07:44 PM
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
Team Role: Coach
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Question Electrostatic Discharge
After having traction issues with our sticky wheels (the chassis was beginning to bend) we have decided to use the slick wheels on the back end of our robot. I notice that several other teams are doing the same thing. Since changing over to the slick wheels we have noticed that after you run the bot on carpet and then go to work on the bot there is a discharge of electricity. One person got zapped several times. We are concerned about our jaguars etc. getting zapped even though they are mounted to a plexi-glass surface. My questions are:
1. Are any other teams noticing a buildup of static electricity after they have opted to use the slick wheels?
2. Are we allowed to run a grounding wire from the ground terminal on the power distribution block to the chassis?
I have posted this with the GDC but have recieved no response yet, your opinions would be appreciated.
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 02-16-2010, 07:49 PM
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Electrostatic Discharge
Other teams have noticed. I believe that http://www.chiefdelphi.com/forums/sh...ghlight=static will give some guidance on this topic.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 02-16-2010, 07:51 PM
JudyVandy JudyVandy is offline
FRC #0084 (Chuck 84)
Rookie Year: 1997
JudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud of
Is it possible that the plexiglas is the problem? Might it be better to mount the 'stuff' on something else?
Unread 02-16-2010, 08:02 PM
rsegrest's Avatar
Team Role: Coach
Lightbulb Re: Electrostatic Discharge
Thank you Eric, I searched ESD and not static buildup when I posted. Will look at the other thread and see what happens. I have also posted to the GDC to get an official answer.
~ Unknown
Unread 02-16-2010, 08:27 PM
DonRotolo's Avatar
Back to humble
FRC #0832
I am very confident that the answer will be no. It won't help, either, but that's beside the point.
To help with ESD, hang some metal braid (or stranded wire with the end fanned out) from the frame until it touches the carpet a little. This provides a discharge path.
Unread 02-18-2010, 09:13 PM
rsegrest's Avatar
Team Role: Coach
I Read in another post that having something brushing the ground would be considered illegal as well. I haven't seen anything in the manual about this directly being legal or illegal. Thoughts?
~ Unknown
Unread 02-18-2010, 11:24 PM
J_Beth J_Beth is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
J_Beth will become famous soon enoughJ_Beth will become famous soon enough
As long as it does not damage the carpet there should not be a problem with it. We use a very fine chain that was hung from the bottom of the robot and just touched the floor last year to help us solve this problem when we had the low friction wheels.
"I Wanna Be A Robot Maker!!!!"
When a Robot Does Rounds Patients Get Faster Discharge JohnBoucher Math and Science 0 07-16-2007 08:03 AM
Battery Life, 50A load discharge test method/results Dale(294engr] Electrical 5 01-22-2006 09:14 AM
