Go to Post Set your goals as high as your team thinks they can achieve (drafted, drafting, win awards, regional champs, world champs, etc) and go for them. Let the chips fall and have no regrets. - BPetry234 [more]
Unread 16-02-2010, 20:30
Wiz Wiz is offline
Wiz is infamous around these partsWiz is infamous around these parts
Question Pressure switch problem
Hey everyone
We have put a pressure switch on our pneumatics system. I programed it to turn of the compressor, but I don't know how to set the pressure it should turn off at. When the compressor runs, the pressure will go up to 110 psi then run out the release valve. Does anyone know how to program a pressure switch to turn of a compressor?
I want the pressure to switch the compressor of at about 100 psi
I am using labview, I am also a first year programmer, so please keep it simple.
thanks
Pressure Switch Problem? P.Svilans Programming 6 09-03-2009 16:47
pressure switch M.Jesus Pneumatics 2 16-02-2008 16:23
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
pressure switch piconysm Technical Discussion 5 14-02-2002 23:15
