Go to Post One of the many unwritten laws of engineering failure is that the problem will occur in the most inopportune time. - Dave Scheck [more]
Unread 16-02-2010, 21:49
Acshi Acshi is offline
FRC #2924
Acshi is an unknown quantity at this point
Hundreds of more watchdog errors even wih the new update
I would have posted this onto the thread of someone who had similar problems, but found that my situation was different enough.
I have just finished installing the new Labview update, cRio image, and driver station updates.
dsVersion 10.02.08.00
cRIO Image LabView - 20010_v20
I am not sure how much is related, but am also getting many errors along the lines of "
ERROR <Code> 1026 occurred at Property Node in
NI_FPGA_Interfaace.lvlib:NIFPGA System.lvlib:Async VI Agent.vi
LabVIEW: VI Reference is invalid
and although probably less related, I am not able to get a battery voltage reading in the ds either.
I have not made any changes to the vision system and can get video easily, though disabling it doesn't help either.
I have not made any changes in the watchdog code for teleop either.
I get the same symptoms in both teleop and autonomous modes, and the ds indicator switches between "... Enabled," "Watchdog Not Fed," and "No Robot Code."
Any help would be appreciated.
Thanks,
Unread 17-02-2010, 03:03
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Re: Hundreds of more watchdog errors even wih the new update
Did you rename your top level VI?
Did you run Start Communication in more than one place?
What exactly did you changes that a caused you to start getting the errors about the invalid VI reference?
Unread 17-02-2010, 13:15
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Rookie Year: 2007
Robototes2412 is on a distinguished road
We have the same probelm, even though we are using java
Unread 17-02-2010, 13:23
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
I would suggest to both teams that you try loading the default framework (only changing the motor references to be appropriate). I haven't seen those errors before, so I suspect it's something you've done to your code.
Unread 17-02-2010, 13:26
1 * 4 != 14
Rookie Year: 2007
I've even tried running "virgin" code and get this error, its prolly a bug in the cRio firmware
Unread 17-02-2010, 13:53
Rookie Year: 1997
If you reimage the cRIO and run the unmodified new project you still get these errors?
Unread 17-02-2010, 14:01
1 * 4 != 14
Rookie Year: 2007
ya, we tried that, itll be bad if it isnt fixed before competition #ni
Unread 17-02-2010, 14:06
Rookie Year: 1997
We haven't been able to reproduce it... so we need you to provide more details as to what could be causing you to have this problem but not us or anyone else.
Thanks,
-Joe
Unread 17-02-2010, 15:45
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
What does your hardware setup look like right now? Are the cRIO modules in their correct positions?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 17-02-2010, 16:06
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Are those System watchdogs or User watchdogs? Can you post a copy of what gets printed to the Driver Station?
Unread 17-02-2010, 22:54
1 * 4 != 14
Rookie Year: 2007
it happens randomly, also being unpredictable.
Unread 18-02-2010, 01:24
FRC #2924
They were user watchdog errors I was getting, I didn't rename any of the default vi's or call Start Communication myself, I re-imaged my cRIO and the virgin code worked fine, so I am slowly reincorporating my code into that, and hopefully will find the breaking point soon.
Unread 18-02-2010, 05:59
For user watchdogs, that is the right approach. As you add in the code, look for things that will take significant time in the code you are adding. Obvious things that will cause this issue are Waits, calls to vision, loops that run for many iterations, etc.
Greg McKaskle
Unread 18-02-2010, 06:02
For the Java user, if we are done #ing NI, can you better describe your symptoms, or have you fixed the problem?
Greg McKaskle
Hundreds of "Watchdog Expiration: System X" Errors lollypop2020 Programming 21 18-02-2010 09:52
Still more watchdog trouble ringo115 NI LabVIEW 3 16-02-2009 10:44
Even More New vex parts!! Chuck Glick VEX 6 04-12-2007 23:18
Even even more Segway stuff. FotoPlasma Dean Kamen's Inventions 1 15-08-2003 22:15
FIRST looses even more ground in the war for TV fame?? archiver 2000 4 23-06-2002 23:53
