Go to Post "FIRST" is not a verb (yet - give us time, and we will see what happens). - dlavery [more]
Unread 17-02-2010, 10:02
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
joystick sensitivity adjustment
Here's a simple algorithm to add sensitivity adjustment to your joystick:
x' = ax^3 + (1-a)x
x is a joystick output ranging from -1 to +1
x' is the sensitivity-adjusted output (also will be -1 to +1)
"a" is a variable ranging from 0 to +1
When a=0, you get x' = x
When a=1, you get x' = x^3 which gives very fine control of small outputs
When a is between 0 and 1, you get something in between. See the GIF file screenshot.
So by adjusting a, you can find the right sensitivity for your driver.
You can find the right value of "a" by trying different values, and then hard-code it, or
If you have a joystick with a "throttle" control (like we do), you can use the throttle control to set the value of "a" (so the driver can adjust it whenever he wants).
Unread 17-02-2010, 11:09
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
Re: joystick sensitivity adjustment
Awesome! I fly model airplanes also and frequently use "expo" on my models to improve the flyability. I've been wanting to figure out how to do it on our robot and this looks like just the trick.
Thanks for sharing!
Adam Bryant
Programming Mentor
Team 1583
Ridge View Academy Rambotics
Unread 17-02-2010, 13:33
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
We worked with that for a while, but found that an exponential curve resulted in too gentle a curve around the Zero point, and hence too large a deadband.
Instead we moved to linear formulas (using 2 X/Y coordinates that we set up as controls in Labview so they could be tuned on the fly).
You can fix the deadband by changing your Y intercept too. It's fun to play with functions like that.
Unread 19-02-2010, 00:07
Talking Re: joystick sensitivity adjustment
We implemented this algorithm on our holonomic drive and it works a ton! I love it! Thanks again for posting this!
Adam Bryant
Programming Mentor
Team 1583
Joystick Sensitivity furiousgeorge NI LabVIEW 15 04-02-2014 23:10
joystick sensitivity gabrielse Programming 2 08-02-2008 14:52
Joystick sensitivity Philz20 Programming 10 24-01-2008 08:34
joystick sensitivity hanan Control System 4 19-01-2007 05:36
joystick sensitivity Team 668 Programming 11 16-02-2005 18:45
