Go to Post I don't need sleep, just more Mountain Dew. Oh, and a muffin. - hallk [more]
Unread 17-02-2010, 11:16
grdaneault grdaneault is offline
FRC #2497
grdaneault is an unknown quantity at this point
Problems with cRIO Saved code
I have saved code onto the cRIO by building the bootup deployment and running it as startup on the cRIO. when the robot reboots, the driver station shows that there is code, but when the robot is enabled, there is no pwm signal to the jaguars. also, the camera feed, which was also working when the code was not saved to the cRIO, is giving a blank screen. when i saved the code to the robot, it there was a message something along the lines of the code included real-time components and would stop any other programs on the cRIO.
is this message related to the problems i am having, or is it just a warning?
also, if it is just a warning, is there anyone that knows what is wrong with the saved code?thanks
cRio Code problems Aaron V FRC Control System 2 14-01-2010 12:59
Issue with debugging/running code on cRio 114Klaatu0x72 Programming 5 27-01-2009 14:02
problems loading code with Easy C Clayton Programming 1 31-01-2008 15:15
Problems with Kevin's 2007 default code bruss6 Programming 8 19-01-2007 15:42
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
