Go to Post The fact that although many of us disagree on specifics of how FIRST should conduct events, design a game, and facilitate as much fairness between teams as possible, in the end we still greatly enjoy each other's passion for FIRST and provide genuine respect for each other - Andy Baker [more]
Unread 17-02-2010, 12:18
alum1880 alum1880 is offline
FRC #1880
alum1880 is an unknown quantity at this point
Help on the Drive train!!!!
My name is Nick James and im from Team 1880. I do programming and I help with the robot.
The problem: The left side of our robot doesn't want to drive backwards, but we can drive forwards with both sides.
We tried:
-changing the motors
-changing the jaquars
-changing the PWM cables
-checking the program
-checking the wiring
-changing digital sidecar
-making sure the gearbox runs(with a battery as a direct source)
We are stumped at this point. If anybody knows or has any suggestions, please post!!!!
Thank You and hope to see everybody at the competition!!!!
Good Luck!!!
Team1880
Unread 17-02-2010, 12:23
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Help on the Drive train!!!!
I am 99% sure that your issue is software. Can you post your code?
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 17-02-2010, 13:51
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The Jaguar speed controller also has a failure mode where it only works in one direction. You could swap pwm cables between sides and see if the problem follows the pwm cable or the speed controller.
Unread 17-02-2010, 21:42
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
We had a similar symptom on our robot several years ago. The root cause was a loose bearing that let the gears disengage when the gearbox was running in one direction. Is your problem that the left side motors don't run in reverse, or that the left side wheels don't move when the motors turn that way? If the motors don't run, can you hear them trying to?
The Drive Train Question. whytheheckme General Forum 5 16-01-2010 21:56
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
Help with drive train superbeano2004 Motors 23 01-02-2005 19:30
pic: team696 teaser of the Drive Train. xKLzKobE08x Extra Discussion 16 30-01-2005 22:59
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
