Legal connections to Air Pumps
The app notes say we can series air connections on two air pumps for more pressure. The app note only shows a way to series two pumps by using a "push me / pull you" approach.
We wish to consider a series of more than two pumps, to make a multistage pump for more power. (Add Tim Allen grunts here... ;-) This won't harm any components, but it does requires a second barb on at least one pump since the pump's second port is merely a slot on the surface of the pump.
What would be the legal and/or recommended way to attach a second air line barb to the air pump to create a series air connection without violating the pump's No-Mod rule?
Would using the same assembly screws that hold the motor and pump together for a removable "barb adapter plate" of some kind violate No-Mod?
If not, what would be considered legal?
Thanks!
- Keith McClary, Huron High Team 830
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
