Go to Post i just want to say how awesome the high volume tank is. The high volume tank is 7/4 as awesome as the previous tanks. - Tytus Gerrish [more]
Unread 02-17-2010, 02:49 PM
mattbutts mattbutts is offline
FRC #1741 (Red Alert)
mattbutts is an unknown quantity at this point
Potential Issue with the C++ CANJaguar Implementation
I have our Jaguars all running in CAN communication mode and the ones that are being controlled in voltage control are working great.
However, when I try to control a Jaguar in position control, I am getting garbage back from the encoder. I verified that everything was setup correctly by testing it with the BDC-COM utility. I can see the encoder perfectly there, and I can tune the controller and it works great.
We have a display for the encoder position on the driver station, and if I watch the value here it jumps around erratically (3 -> 8 -> 11 -> 65535 etc.). This makes me think it has something to do with the way the code is unpacking the data from the CAN messages, but I am not familiar enough with the messages to know that this is the case.
I guess my real question is: Has anyone else been able to get meaningful data back from a CANJaguar, and if so, did you have to do anything special? I really need to be able to get the position reliably.
Thanks,
Matt
Weird issue with the power distribution block X-Istence Electrical 17 03-08-2009 06:32 PM
[FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob PackersFan FIRST Tech Challenge 11 01-26-2009 09:25 PM
An Issue with downloading the Master Code. Neil [Coconuts] Programming 6 02-07-2008 02:03 PM
Issue with downloading code to the 2007 RC thefro526 Programming 3 02-10-2007 05:26 PM
Potential Problem with "fighting over the goal" Kyle Fenton General Forum 4 02-17-2002 10:21 AM
