Thread Tools |
Rating:
Display Modes |
Default function pinouts on Psoc I/O board
I feel like a dummy asking this, but I can't find out what the default pin/function mappings are for the Cypress board.
I have the "actual" pin/function designations, but where are the "compatibility" functions identified... eg: there are 8 analog inputs on the board, but only 4 in the default "DS Compatibility" interface.... so.. I'm to assume that we only use analog channels 1,2,3 & 4 on the Cypress board?? But what about the digital channels. DS Compatibility interface has 8 digital inputs and 8 digital outputs. It "appears" that cypress digital channels 1-8 corrospond to the inputs, and 9-16 corrospond to the outputs, but I'm just guessing.... Is this written up anywhere? I'm assuming it is, I just can't find it. Phil. |
Re: Default function pinouts on Psoc I/O board
The second 8 are outputs. Note that if you were to move to the enhanced I/O configuration, you can make a definitive selection of each pin assignment, control direction of pull (or floating) on inputs, eliminating any doubt and guesswork. |
Does this help?: http://www.chiefdelphi.com/forums/at...2&d=1264090529
Does anyone know if the default Digital Outputs are configured for 4mA current source, 8mA current sink, or 25mA current sink?
I'm going to rewire an output and I would like to know what I'm working with. Thanks to the info on this thread I figured out we currently it connected to digital input 4 instead of digital output 4 (and that is why it is always on ) |
http://www.usfirst.org/uploadedFiles...t%20tables.pdf It contains the information you are looking for. It falls short in describing how the pin-out looks for compatibility mode, but its a modest guess (and the above info on this thread should do it). If you use enhanced IO, you can set it up however you wish and eliminate any guessing. |
The FIRST pinout lists these modes for the digital pins: Quote:
| Windows "Malfunctioning USB Device" error with Psoc IO Board | WarrenPW | FRC Control System | 2 | 11-02-2010 18:53 |
| Wiring Switches to the PSoC board | Raj1977 | Electrical | 13 | 07-02-2010 23:24 |
| Camera Pinouts? | kiettyyyy | Programming | 7 | 09-04-2006 10:12 |
| Pinouts | CronosPrime1 | Programming | 1 | 04-02-2006 22:54 |
| RNet Pinouts | archiver | 1999 | 1 | 23-06-2002 23:18 |
