new motor
Code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Relay;
public class Demonized extends SimpleRobot {
private static final long TIME_DELAY = 1000; // in milliseconds
RobotDrive drive = new RobotDrive(1, 2);
RobotDrive spot = new RobotDrive(3);
Joystick leftStick = new Joystick(1);
Joystick rightStick = new Joystick(2);
Joystick kicker = new Joystick(3);
Watchdog fenrir = Watchdog.getInstance();
Compressor fluffy = new Compressor(1, 1);
void setUpRobot() {
fluffy.start();
fenrir.feed();
public void autonomous() {
setUpRobot();
try {
while (true && isAutonomous() && isEnabled()) {
for (int i = 0; i < 4; i++) {
fenrir.feed();
Thread.sleep(TIME_DELAY);
drive.drive(0.5, 0.0); // drive 50% fwd 0% turn
fenrir.feed();
drive.drive(0.0, 0.5); // drive 0% fwd 50% turn
fenrir.feed();
drive.drive(0.0, -0.5); // drive 0% fwd -50% turn
drive.drive(0.0, 0.0); // drive 0% fwd, 0% turn
} catch (InterruptedException ie) {
// aaaaaaah, how do we log this out?
// but make sure we stop
public void operatorControl() {
setUpRobot();
while (true && isOperatorControl() && isEnabled()) // loop until change
drive.tankDrive(leftStick, rightStick);
Timer.delay(0.005);
fenrir.feed();
drive.arcadeDrive(kicker);
any help. Last edited by Twisted eric : 02-17-2010 at 04:08 PM. Reason: fix |
Re: new motor
I'm imagining that this doesn't compile, since there isn't a RobotDrive constructor that takes only one int parameter. Also, in operatorControl() you're setting the drive motors based on input from two joysticks, and then setting them again based on input from a third joystick. This isn't going to produce a desirable result.
If you want to control a single motor with a joystick, use the appropriate SpeedController class -- Jaguar or Victor. RobotDrive is intended for use with drive trains that have two or four motor configurations. Code:
Jaguar spot = new Jaguar(3);
setUpRobot();
spot.set(kicker.getY());
Timer.delay(0.005);
fenrir.feed();
Re: new motor
got it working thanks
| New FP motor at event | Pat Major | Motors | 1 | 02-14-2005 04:57 PM |
| New Drill Motor Mounts | MattB703 | Motors | 1 | 01-08-2003 09:46 PM |
| New Drill Motor Mounts | MattB703 | Technical Discussion | 0 | 01-06-2003 09:31 AM |
| New Fisher Price Motor - IMPORTANT | Paul Copioli | Motors | 6 | 02-08-2002 01:35 PM |
| What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. | Robb Gerber | Motors | 2 | 01-23-2002 08:58 AM |
