Go to Post our family has no borders... - Greg Hainsworth [more]
Unread 02-17-2010, 04:28 PM
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Windriver Project will not open
The essence of our problem is merely that although we can open individual files on WindRiver, we cannot open the full project, and the "Open Project" option under the Project tab is greyed out, and is unclickable. None of our many versions of code are showing up in our project explorer. Thank you in advance for your help!
-Wiifi
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 02-17-2010, 04:51 PM
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Windriver Project will not open
-Wiifi
If you have no closed projects, you will not be able to open any projects.
If you have a closed project, you need to highlight it to open it -- you can right click on a closed project and open it using the context menu.
If your project explorer view shows no projects (and you know you had projects at one time), your workspace is probably hosed.
Why don't you post a screen shot showing the project explorer?
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 02-17-2010, 05:13 PM
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
http://s775.photobucket.com/albums/y...jgcfg xfd.jpg
Here, i think i uploaded it right. there is absolutely nothing in the project explorer.
-Wiifi
Unread 02-17-2010, 05:27 PM
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
-Wiifi
Ok, the obvious question then is -- did you have projects showing at some point?
Do you have a directory called c:\windriver\workspace?
If so, is there anything in it?
Hopefully, you didn't inadvertently delete your projects?
Edit: I can see from your screenshot that you do have a c:\windriver\workspace directory.
Unread 02-17-2010, 05:31 PM
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
We can still open the .cpp, but we just can't seem to open the project itself.
We still have all of the fies, and even the project file we are looking for is in there, but it can not be opened.
-Wiifi
Unread 02-17-2010, 05:47 PM
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
Rookie Year: 2010
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Have you tried creating a new, empty workspace, and then adding/importing your project into the new workspace?
Just go to File->Switch Workspace, and give a directory to a new workspace. Once you've done that, you can create new projects or import an existing one.
If that doesn't work.. Ummm.. Maybe check that the workspace directory (or even project directory) isn't read only?
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 02-17-2010, 05:49 PM
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
You should make a copy of your current workspace directory and then try to import the projects you want to get back.
In the project explorer view, right click and then select Import from the context menu.
That will pop up an Import dialog.
There you should select General->Existing Projects into Workspace -- click Next.
The dialog will change and you want to select "Select root directory" and click the Browse button.
Browse to c:\windriver\workspace and then click OK.
With any luck, you will be shown some number of (salvageable) projects.
Check those you want to recover.
I would try recovering just one project at first.
If it works out, then recover any others you need.
Please let us know how this turns out and don't forget to make a copy of the workspace directory FIRST!
After updates windriver will not connect to cRIO z.s.tar.gz C/C++ 5 02-17-2010 05:08 PM
[WindRiver]Creating a fresh buildable project ProgrammerMike7 C/C++ 5 01-30-2010 07:33 AM
Windriver - Cannot Create New Example Project Aaron S C/C++ 6 01-19-2010 09:25 PM
help:Downloading the project in windriver mahmosh C/C++ 5 01-10-2009 10:08 AM
Open Automation Project UIDzero Robot Showcase 7 11-13-2003 10:06 PM
