Go to Post resist the hive: As goofy as this may sound, wires do take up weight, several pounds of it. - Rickertsen2 [more]
Unread 17-02-2010, 18:23
FRC2669_Valery's Avatar
FRC2669_Valery FRC2669_Valery is offline
Team Captain & Programmer
AKA: Valery Davidov
FRC #2669 (KY Bots)
Team Role: Leadership
FRC2669_Valery is an unknown quantity at this point
Send a message via ICQ to FRC2669_Valery Send a message via MSN to FRC2669_Valery
Autonomous Mode, Independent, Iterative (?)
Hello, My Name is Valery and I'm the lead programmer in our team, 2669, Kiryat Yam, Israel.
My experience with autonomous mode is tiny.
while trying to write an autonomous mode I bumped into a problem.
I couldn't figure the independent and iterative modes and didn't understand what to choose.
finally I've chosen the independent because I understood that this vi does the program one time and then stops.
but I saw that in the Main VI there's a referral to the iterative vi, should I change it to the independent ? in the iterative vi there's a case structure that leads to an independent autonomous but the case is empty, should I put there the independent auto' VI ?
How can I "tell" the robot that I'd like him to use the independent autonomous and not the iterative?
thanks, valery
Unread 17-02-2010, 19:50
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Autonomous Mode, Independent, Iterative (?)
In Begin.vi, there is a selection for independent and iterative. Independent is selected by default. The default framework has references to both, but it only runs what you have selected in begin.
Unread 18-02-2010, 00:47
AKA: Valery Davidov
FRC #2669 (KY Bots)
so if I choose independent autonomous, Where should I put my code?
in the Independent VI or in the iterative vi in the independent case ?
thank you, valery
Unread 18-02-2010, 02:01
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Autonomous_independent.vi will be called when autonomous begins and terminated when it ends.
Autonomous_iterative.vi will be called at 50hz during Autonomous. The purpose of putting some Independent code in Iterative is to handle periodic tasks that must be run in a loop, such as feeding the watchdog.
So what you will want to do is feed the watchdog in Autonomous_Iterative.vi and put the rest of your code in Autonomous Independent.vi
Kettering Motorsports
Unread 18-02-2010, 09:50
Rookie Year: 1997
Doing that may be no better then disabling the watchdog. If you have an error in your code in autonomous independent, the watchdog would continue getting fed. It's better to completely ignore the autonomous iterative, and put all your code (including feeding the watchdog) in autonomous independent.
global variables and autonomous independent Team1824 NI LabVIEW 10 19-02-2010 23:00
Autonomous (Iterative) j.cole NI LabVIEW 6 12-02-2010 02:01
Autonomous Independent Code Issue Watchdog not fed pilum40 FRC Control System 0 11-02-2010 12:00
Continuous vs. Autonomous in Iterative Robot Shira C/C++ 4 06-02-2009 04:20
Using Sensors in Autonomous Independent Felipe Sagui NI LabVIEW 2 27-01-2009 17:25
