Go to Post do the math, then use the math to go for total overkill. - pfreivald [more]
Unread 17-02-2010, 20:29
lsprague lsprague is offline
FRC #3256 (WarriorBorgs)
lsprague is an unknown quantity at this point
Programming Pots
We planned to set up joystick buttons to make the kicker move to a set position using potentiometers, but it keeps overshooting and getting stuck. Here's what we have:
Code:
if(rightstick->GetRawButton(HIGH_POT_BTN))
while(kickerValue != HIGH_POT)
GetWatchdog().Feed();
if(kickerValue>HIGH_POT)
winch->Set(Relay::kForward);
else
winch->Set(Relay::kReverse);
else
winch->Set(Relay::kOff);
We tried using if instead of while because of watchdog problems, but that would only work by holding the button down. Now, the kicker pulls back too far and gets stuck. Does anyone know if it's a problem in the code or in the numbers we used for the pots?
small joystick pots?? Bruceb Control System 1 18-02-2008 11:59
10 turn 100k pots rust710 Electrical 5 02-04-2003 15:10
Limit Switches/Pots Brett W Technical Discussion 3 28-01-2003 14:25
THIS IS AN OT POTS!!!!!1!!!! (EOM) archiver 2001 0 24-06-2002 03:17
3-turn pots archiver 2001 2 24-06-2002 01:24
