Bungee Cables on Robot
Are we allowed to attach bungee cords around the edge of the robot, to shield off balls from our undercarriage?
Obviously the bungee cables cannot go outside the bounds of the robot/bumper, but if we run them just outside the robot, we can make sure soccer balls are not trapped underneath our robot (it is on the KOP risers). We would just have the bungee cables hooked taut into holes drilled into the chassis... Thanks. |
Re: Bungee Cables on Robot
There is no rule that I am aware of that forbids this.
Just make sure the bungees won't be able to fall out. |
Is it an issue if the bungee/surgical tubing rubs along the carpet while the robot climbs the bump?
There is no rule that I know of preventing that.
The only rule that I remember is about traction devices and floor damage. |
JMHO, Mike |
bungie cables are springy, and have alot of "give"
May I suggest pneumatic tubing? My team is using pneumatic tubing (2 strands of it at varying heights) to keep balls out from under our robot. It has alot less "give" and pushes the balls straight back out with no problem... It is also slightly stretchy, so even putting it about 4 inches off the floor (like we have on our robot) it can still negotiate the bump with no friction to hold it back, and they spring right back into place. Use a "G" sized drill bit to drill through what you want to mount it to, then use a #10 bolt (about a 3/4 inch length) and a nice washer to keep it from going back through the hole... the #10 bolts work beautifully on pneumatic tubing, and form an almost indestructible bond when threaded all the way into the tube... this is just my $0.02 suggestion we were testing the "impenetrability" of the undercarriage of our robot, and one of the members threw the ball at the side of the bot, and the tubing threw it straight back at him with ehough force to knock the glasses right off his face lol and it did not even break the 3" plane rule ![]() |
WW,
Your concerns are founded in that the bungies could be dragged outside the FRAME and are not interacting with the ball. The two second rule applies to ball interaction. However, a team must also insure they are not in possession of more than one ball at a time. Choose wisely! |
| Bungee cords illegal on Robot? | Chath Maral | Kit & Additional Hardware | 2 | 23-01-2010 15:04 |
| bungee chords | Matt21q | General Forum | 1 | 19-02-2007 19:16 |
| Bungee Bracket? | Bomberofdoom | Technical Discussion | 1 | 31-01-2007 13:08 |
| Bungee Cords | APRUZ17 | OCCRA | 1 | 25-10-2003 16:12 |
| Springs, Bungee cords...etc. | Mr. Mac | OCCRA | 0 | 20-10-2003 22:37 |
