Go to Post ... if there is no standard against which you determine success, then you can never fail. - dlavery [more]
Unread 17-02-2010, 22:06
Natesbug73 Natesbug73 is offline
FRC #3168
Natesbug73 is an unknown quantity at this point
Plywood question
At my local Lowes the only plywood available in 3/4 inch thickness is birch, instead of regular cheap plywood. The sizes of regular plywood are odd like 15/32 and such. What did everyone else use, is one of the oddball sizes ok?
Unread 17-02-2010, 22:08
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Re: Plywood question
We use 18mm baltic birch. Its the metric equivalent to 3/4" plywood and much stronger
Mentor 2415
Unread 17-02-2010, 22:10
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
The rules say 3/4" plywood. A team asked if they could combine a 1/2" and a 1/4" piece. GDC said no, even though it would be 3/4" thick. http://forums.usfirst.org/showthread.php?t=14464
If Lowe's doesn't have cheap 3/4" ply, try the other hardware/lumber stores in town. Failing that, go with the birch.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 17-02-2010, 22:19
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Most construction plywood that is nominally 3/4" is actually 23/32. You should ask on the official Q&A, but I seriously doubt you would have a problem with either 23/32" or 18mm.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 17-02-2010, 22:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We too are using 18mm Russian Baltic Birch, and it is fantastic. It has about 13 plys, and is very strong.
Unread 17-02-2010, 22:44
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Team Role: Mechanical
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
what exactly is this plywood for?
I don;t remember there being a rule against using certain thicknesses of plywood :|
last year, our team used 1/4 inch luon on our controll board...nobody said anything
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
Unread 17-02-2010, 22:46
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Rookie Year: 2007
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
Bumpers
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 18-02-2010, 17:07
FRC #3168
Yeah I think that's what I'll do. 23/32 is what they have. The birch is about 2x the price.
Electronic Devices on Plywood?? cilginbilgin Electrical 2 13-02-2010 11:08
pic: 3/4" Plywood Frame ,4lex S. Extra Discussion 11 02-12-2009 22:32
Bumper Plywood Backing Skifanatic Technical Discussion 3 10-02-2009 18:20
Wheels - Plywood Denman Technical Discussion 10 04-02-2004 08:38
Question about Plywood thickness KennethToronto Technical Discussion 4 06-02-2002 15:20
