Go to Post I like how we're trying to save weight when we came in at 95 pounds. - Chris is me [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 17-02-2010, 22:27
KillerGardevoir KillerGardevoir is offline
FRC #2865 (Roboteknix)
KillerGardevoir is an unknown quantity at this point
CAN with more than 2 Jaguars
I am having trouble setting up CAN with more than 2 Jaguars (black to gray). I have tried everything i can think of to make it work, all the cables work, the terminating resistor works, the jaguars work, the RS232 to RJ-12 works, we are connected to a computer with an serial port (no usb emulator), the firmware has been updated to revision 87. It can see two by putting a black then a gray with the terminating resistor, but the moment I attempt to attach a third jag (gray or black) to the network it can only see the first in the series. Also I can't seem to get two black jaguars to connect together.
Unread 17-02-2010, 23:07
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: CAN with more than 2 Jaguars
Have you setup an ID on the grey jag? All jags default to ID 1 and if multiple jags share an ID the bus gets messed up. Also have you tried switching up the cables? Perhaps you didn't make the second cable properly
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 17-02-2010, 23:15
I have done this already, double checked the ID's and we have 4 cables that are verified working.
Unread 18-02-2010, 03:50
Ok so I resolved the issue, it turns out it was the cables. Two were fine, but the other two were damaged, so they have to be remade. Long story short, show all team members making cables how to properly make cables.
Unread 18-02-2010, 08:57
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by KillerGardevoir View Post
...the terminating resistor works,...
You need two terminating resistors, one at each end of the bus.
That would not be unusual behavior if you're missing the resistor at the beginning of the chain. Termination problems regularly manifest themselves at the other end of the bus from the fault.
Unread 27-02-2010, 01:40
cmoon71 cmoon71 is offline
Mentor
AKA: Chuck Moon
FRC #3015 (Ranger Robots)
Team Role: Leadership
cmoon71 is an unknown quantity at this point
We are having problems using more than 3 Jag on the CAN bus. Using the BDC-comm, when we add a 4th Jag, all we can see is the 1st Jag! We are using 120 ohms as a terminator between CANH (3) and CANL (4) plugged into the Last Jag on the bus as Black Jaguar 2010.pdf shows. Is this right?
Unread 27-02-2010, 08:08
Software Architect
Is the terminator at the cRIO end of the bus connected properly?
Unread 27-02-2010, 08:57
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
Rookie Year: 2010
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
I've found that the approach of placing the terminator resistor into the connector, as shown in the GSG, is way too prone to shorting out with repeated insertion and removal cycles. I feel that your best course is to run the wires for the terminator a short distance out of the connector and solder/heat shrink them outside of the RJ-12. That seems to stand up better and avoid the easy short that happens when the two resistor legs touch each other in the connector (they're on adjacent pins).
HTH,
Mike
Unread 02-04-2010, 13:06
TRay TRay is offline
FRC #1817
TRay is an unknown quantity at this point
True, but a little hot glue fixes that quite well.
Unread 03-04-2010, 01:20
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Or epoxy works too, but crimping that little resistor in was a pain.
As a matter of preference, solder, but as far as aesthetics (And difficulty of removal ), crimping.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
More Thank You's Than 1902 Can Handle Matt_Kaplan1902 Thanks and/or Congrats 0 28-04-2009 15:26
Can you install windriver on more than 1 pc? programmr Programming 7 12-12-2008 20:15
more than 4 ir controls? Vanquish Programming 2 12-01-2008 14:52
pic:Can you pick balls up from more than one place??? sgsdragons General Forum 9 02-03-2006 12:59
Edit- Can we connect more than one speed controller fan per breaker? DemonYawgmoth Rules/Strategy 7 03-02-2006 21:37
