Go to Post Build a student a robot and it will keep him/her busy for a few days in the spring. Teach a student how to build(design, wire, program) a robot and they will stay away from home, use some really strange language and wear funny clothes the whole year long. - Al Skierkiewicz [more]
Unread 17-02-2010, 22:47
1195mentor 1195mentor is offline
FRC #1195
1195mentor is an unknown quantity at this point
Desperate for watchdog help
Hello,
Last year we programmed in LabView and though we would try Java this year. We are in Maryland and we have lost 2 weeks due to snowstorms and are basically back at square one with programming. Our teleoperated code keeps shutting down because we aren't feeding the watchdog though we have tried to use the examples in the Getting Started guide. I would greatly appreciate any assistance you can provide
Here is the code
/* Copyright (c) FIRST 2008. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the SimpleRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class Wednesday extends SimpleRobot
private RobotDrive drivetrain;
private Joystick leftStick;
private Joystick rightStick;
public Wednesday()
drivetrain = new RobotDrive(1, 2, 3, 4, 0.5); //create RobotDrive
leftStick = new Joystick(1);
rightStick = new Joystick(2);
public void autonomous() {
getWatchdog().setEnabled(false);
// rtimer.start();
while (true && isAutonomous() && isEnabled()) {
for (int i = 0; i < 4; i++)
drivetrain.drive(0.5, 0.0); // drive 50% fwd 0% turn
Timer.delay(2.0); // wait 2 seconds
drivetrain.drive(0.5, 0.75); // drive 0% fwd, 75% turn
drivetrain.drive(0.0, 0.0); // drive 0% forward, 0% turn
* This function is called once each time the robot enters operator control.
public void OperatorControl()
getWatchdog().setEnabled(true);
while (true && isOperatorControl() && isEnabled()) // loop until change
{getWatchdog().feed();
// Watchdog.getInstance().feed();
drivetrain.tankDrive(leftStick, rightStick); // drive with joysticks
Timer.delay(0.005);
/* the project. */
Thank you very much!
Need a Full "Watchdog for idiots" explanation K Lenox NI LabVIEW 9 16-02-2010 14:10
Desperate need of help MrExploiter Programming 9 25-02-2008 22:38
Desperate for help in camera tracking itsme Programming 9 06-02-2007 15:55
In desperate need of some help archiver 2000 0 23-06-2002 23:40
desperate help Andrew Dahl General Forum 0 21-11-2001 12:08
