Is the Signal light Supposed to Blink or Be steady?
Ok..we've wired up the signal light and it works-blinks! We're living LARGE huh?
Is the light supposed to blink in the competition or stay steady? I figure that's the reason there's a crossover + wire on the diagram. I really don't want to change what is working at this late date. Any help would be appreciated!Thanks! |
Re: Is the Signal light Supposed to Blink or Be steady?
It should do the same thing as the small LED next to where you plug the signal light into on the digital sidecar. The extra wire is required by <R59C>.
It's a lot easier to make changes now then after inspection at competition. |
Before network communication is established, the RSL should blink quickly.
When the robot is disabled, the RSL should blink slowly. When the robot is enabled, the RSL should be on with a brief flicker off every second and a half. (I think the RSL is on solid during autonomous mode.) If your big amber light isn't doing exactly the same thing as the little green one on the Digital Sidecar, you probably don't have the connection between its outside pins installed properly. |
I went back and wired it correctly as per your post! Works like a champion! This forum rocks! Thanks! |
If you're ever looking for what the exact blink codes are for the RSL they are on the last page of chapter 1 of the control system manual http://usfirst.org/roboticsprograms/....aspx?id=10934
| Robot Signal Light | smcmahon | Electrical | 20 | 08-03-2009 18:11 |
| Question about the signal light | Carmelulu` | General Forum | 2 | 05-02-2009 23:08 |
| HELP WITH THE LED SIGNAL LIGHT | Bre92 | Electrical | 2 | 27-01-2008 22:31 |
| Signal Light | DustinB_3 | Electrical | 10 | 21-02-2007 13:10 |
| Whats the Robot Signal light for? | steve d | Electrical | 12 | 20-02-2007 08:29 |
