Go to Post Teams whose goal is to play on Einstein think about strategy differently from teams whose goal is to be selected for an alliance at a district event. - alopex_rex [more]
Unread 18-02-2010, 10:18
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Non-Standard Wireless Configuration
Can anyone clarify the problems associated with enabling the 2.4GHz radio with a second SSID and connecting the Classmate over wireless to the router? This also enables a second programming laptop to connect over wireless as well. It seems to work most of the time for us. We get a higher number of dropped connections than over wired (that seems like an obvious statement). It seems like these two networks shouldn't interfere with each other, however. Does anyone know what's causing the issues with this configuration?
Unread 18-02-2010, 10:26
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Non-Standard Wireless Configuration
There's issues with this configuration? In our lab, we have the wifi router hanging off the school's network in the classroom, with the robot and classmate on wireless (over the 5ghz and 2.4ghz radios respectively). Also, our programming laptop is wireless.
This configuration we have also allows us internet access on the programming computer and classmate... and theoretically the cRIO too
Unread 18-02-2010, 12:52
Do you ever have connection issues with the cRIO. Half of the time I can't connect to or ping it from the wirelessly connected laptops.
Unread 18-02-2010, 13:39
I have issues sometimes with a hard power-cycle on the robot, but if i reboot it using the reboot robot button on the classmate its all good.
I compile my C++, download to robot on programming laptop
Then click reboot robot on classmate
wait ~10s
click enable.
I only have issues if I power down the bridge. If that happens, I find I can get it going by using the programming laptop and pinging 10.xx.yy.1 (the bridge) and 10.xx.yy.2 (the cRIO).
Unread 18-02-2010, 20:03
The cold boot issue is worked around with the latest DS upate, 1.1.
Greg McKaskle
Using non KOP router, possible cause of wireless communication issues? saba Programming 10 31-01-2010 13:22
Non-standard USB controllers with the OI CapnKernel FRC Control System 1 31-01-2010 02:08
Wireless Thermometer Wireless Data C222 Technical Discussion 9 11-01-2010 08:01
Standard Joysticks EricWilliams Programming 26 01-04-2006 22:59
Non-Standard Broaching sanddrag Technical Discussion 3 17-03-2004 11:46
