Go to Post And - I would never ever underestimate a rookie. Ever. - JaneYoung [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 18-02-2010, 11:44
Gary Bonner Gary Bonner is offline
FRC #3974
Rookie Year: 2000
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Labview PID
The 2010 FRC Vision Whitepaper discusses tuning the PID in the example code. The document first discusses the parallel PID formula, which has separate gains for P, I, & D, and the academic formula, which Labview uses, and which has only one gain. The coefficients of the I & D terms are time periods. The paper then discusses tuning the P, I, & D gains. Do they mean the periods for I & D? Also, when tuning the P term, the I & D terms are to be set to 0. For the I term, since the period is in the denominator, should it be set to a large value to zero out the term? How large? Or is there another way to zero out the terms?
Thanks!
Unread 18-02-2010, 20:31
Re: Labview PID
I apologize if the paper slipped up and referred to them as gains. How about coefficients?
The paper is trying to document a procedure for tuning all three coefficients. As for the meaning of zero, I didn't look at the implementation, but it seems that zero is a special value which turns off that term. After all, having an infinite term probably doesn't give a good output anyway.
Greg McKaskle
PID Control Geek 2.0 Programming 16 12-01-2010 21:10
PID: P+D or P-D billbo911 Programming 1 27-01-2008 23:52
PID shadowops06 Programming 5 16-06-2006 22:48
PID without a Ph.D. Joe Johnson Programming 3 07-02-2006 17:37
PID Control Chris Bright Programming 9 26-03-2005 19:44
