Wireless Reset Issues and problem resetting
So someone on our team decided to reset the gaming adapter, and now we can't go into the router page (192.168.1.1 & 192.168.1.250) and yeah.. If we can't access the page then we can't change the settings from factory settings back to FRC settings. btw since we're a veteran team do we still use 192.168.1.1 even though we reset it o factory settings
Is there anything we can do? we followed the instructions from here-http://usfirst.org/uploadedFiles/Community/FRC/Game_and_Season__Info/2010_Assets/2-2010FRCControl%20System-Getting%20Started-Rev-0.7.pdf so far we have an eternet cable from the jack to the router. another cable from driver station to router.. we have the gaming adapter connected from the crio to the router... any mistakes? and yeah no luck.. any help? Last edited by batmankiller : 18-02-2010 at 14:16. |
Re: Wireless Reset Issues and problem resetting
Connect your PC by ethernet cable directly to the Gaming Adaptor.
Change your PC IP address to 192.168.1.5 (make sure the Driver Station application is not running and your wireless is off). Browse to 192.168.1.250 |
Thank you so much, you are the best person in life! oh btw.. do we still use the .250 ip address if we're a veteran team?
If you have last year's WGA600N, then the default address is 192.168.1.250
If you have a new WET610N, then the default address is 169.254.1.250 You need to follow the setup directions in the Getting started manual for the Gaming Adaptor, so the IP will be reset to 10.26.01.01 |
| Wireless Connection issues | Techwiz | Technical Discussion | 16 | 05-04-2010 01:13 |
| Wireless issues | Sauce | Programming | 3 | 30-01-2010 15:02 |
| Wireless Issues | MacAddict | FRC Control System | 6 | 25-01-2009 20:58 |
| Gyro resetting and recalling? | Tom Line | Programming | 1 | 17-02-2008 09:05 |
| Camera won't initialize when reset from RC - reset from OI and Power-up works, | krunal | Programming | 7 | 15-01-2007 00:13 |
