Go to Post FIRST Championships event is not about winning, its about the experience, the atmosphere, the people and the sites, there are a lot of amazing things to see at The Championships. - Mike Schroeder [more]
Unread 18-02-2010, 15:30
MPG's Avatar
MPG MPG is offline
Tutu Man
AKA: Michael
FRC #1259 (Paradigm Shift)
Team Role: Electrical
Rookie Year: 2007
MPG is an unknown quantity at this point
Rotating camera image
Hey, we have got our axis camera working with the robot. Right now we have the camera mounted sideways (rotated 90 degrees) and we can figure out how to rotate the image one the dashboard 180 degrees but not 90 degrees. Is this possible and if so could you let us know how to change this. Thanks
Team Robot Names
2010 = Oswald
2009 = Black Magic
2008 = Barnaby Rover
2007 = Z
2006 = Dilbert
2005 = Oder
2004 = Gerry
Unread 18-02-2010, 15:38
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Rotating camera image
What Language?
In LabVIEW: Go to the functions palatte, then to Vision and Motion -> Vision Utilities ->Image Manipulation. You will find a VI called "Rotate Image", with an input (double type) for Degrees. I recommend doing this on the Classmate end as the cRio is already doing a lot of work to handle vision processing.
I don't know about other languages.
Kettering Motorsports
Unread 18-02-2010, 15:42
MPG's Avatar
MPG MPG is offline
Tutu Man
AKA: Michael
Rookie Year: 2007
We are using JAVA but thank you for the quick responce!
Team Robot Names
2010 = Oswald
2009 = Black Magic
2007 = Z
2006 = Dilbert
2005 = Oder
2004 = Gerry
Unread 21-02-2010, 20:38
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
We are having trouble rotating the image 180 degrees using Wind River. I see the rotate function, but it doesnt actually do anything when I call it. Other camera functions like WriteBrightness and Write Resolution do not work either. Do I need to call something after those functions to finalize the changes?
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 22-02-2010, 12:43
elfinn elfinn is offline
Team 166 Mentor
AKA: Beth Finn
FRC #0166 (Chopshop Team 166)
elfinn is an unknown quantity at this point
It works for us. After creating our camera object (camera166), we call
camera166->WriteRotation(AxisCameraParams::kRotation_180);
This actually stops and restarts the camera so you have to wait a few seconds.
Unread 22-02-2010, 16:49
AKA: Joey
How and where are you doing this? To declare it did you just do AxisCamera &camera = AxisCamera::GetInstance();? I have all our camera code in robot init. It has the GetInstance of the camera, then write brightness, compression, and rotation, however none of those functions work. I just get the default video on the screen.
no camera image in the dashboard Team_136 Control System 3 23-02-2010 18:49
Camera Image Delay taysonholzer C/C++ 6 18-02-2010 10:59
Camera image? P.Svilans Programming 1 09-03-2009 17:20
Invert camera image? mcb NI LabVIEW 2 21-02-2009 13:23
Rotating Light - not rotating :-/ MrB Technical Discussion 17 08-02-2002 20:36
