Go to Post the programmers are -- um, well, doing what programmers do: drinking more Mt Dew. - Roger [more]
Unread 02-18-2010, 04:42 PM
Mr. Stone Mr. Stone is offline
FRC #1622 (Spyder)
Mr. Stone is an unknown quantity at this point
Spike Relay works only in Reverse
Hi,
We want a button to start the relay in reverse, and one for it to go forward. We also have a button to make it stop. The problem is that the spike is only getting the signals to send it in reverse and to stop.
our code for it is as follows:
Code:
// We need to decide what buttons belong to which functions.
			AvoidTipOver(joyBtnShooter7Pushed,
						 joyBtnShooter8Pushed,
						 joyBtnShooter9Pushed,
						 joyBtnShooter5Pushed);
//these are all configured properly, at one point, we were using this for our pneumatics
void AvoidTipOver(bool btn7,
					  bool btn8,
					  bool btn9,
					  bool btn5)
		// tells the tipBarLeft/Right to be able to work both directions, but it does not seem to
		// be working at the moment, tweak this to make it work better.
		tipBarLeft->SetDirection(Relay::kBothDirections);
		tipBarRight->SetDirection(Relay::kBothDirections);
		if (btn8)
			tipBarLeft->Set(Relay::kForward);//when btn8 is pressed we want it to be set in the forward position.
		if (btn9)
			tipBarLeft->Set(Relay::kReverse);//when btn9 is pressed we want it to be set in the reverse position.
		if (btn5)
			tipBarLeft->Set(Relay::kOff);//when btn 5 is pressed we want it to stop.
		tipBarLeft = new Relay(TipBarLeft);
		tipBarRight = new Relay(TipBarRight);//not used at the moment, we are just testing on a mock-up board.
		tipBarRight->Set(Relay::kOff);
The relay is on channel 1 and is getting power. When we press button 9, it goes in reverse. When we press button 5, it stops. When we press button 8, it stays in the off position.
thanks,
Mr. Stone
spike relay problem? Maxpower57 Electrical 15 04-09-2012 07:18 PM
Relay bug, doesn't work in Forward or Reverse only modes Joe Ross NI LabVIEW 0 02-16-2010 11:33 PM
Relay (Spike) elbuo Electrical 2 02-09-2009 08:36 PM
Making a forward only speed control reverse sanddrag Electrical 7 12-12-2003 07:19 AM
Spike Relay Input nwagers Electrical 3 07-16-2002 10:23 PM
