Go to Post changing some 0 to 1s was a lot lighter and cheaper than most of the clutches I found. - IKE [more]
Unread 18-02-2010, 18:23
Spatacus Spatacus is offline
FRC #2432
Spatacus is an unknown quantity at this point
IP Adress Problems
When we set up the IP adresses the correct way we don't get communication but when we have the classmate IP address set up to 10.24.32.5 the robot will move but the motor will be spotty and not move fluidly. How do we fix this?
Unread 18-02-2010, 20:15
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: IP Adress Problems
Since the classmate IP address is supposed to be 10.24.32.5, I'm not sure what you mean...
Unread 19-02-2010, 18:28
FRC #2432
I meant to say 10.24.32.6. When we have it set up to .5 the robot moves but the motors don't run fluidly.
Unread 20-02-2010, 12:31
FRC #2432
isnt the the IP adress of the drivers station is 10.24.32.5? when we set the IP adress of the classmate to 10.24.32.5 we have an IP adresss conflict with the drivers station.
Unread 20-02-2010, 13:13
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
The classmate is the driver station. It is supposed to be set to 10.24.32.5 as Mark said. Are you using something else as your driver station?
As for the motors cutting out, see if you're feeding the watchdog just a little bit too late.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Setting the i.p. adress tomy NI LabVIEW 2 12-01-2010 22:24
DS Problems popo308 FRC Control System 3 05-01-2009 22:16
IR Problems Tottanka Electrical 3 13-01-2008 15:07
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
New Website adress for teams Elgin Clock CD Forum Support 1 08-01-2002 09:16
