Go to Post There are certain questions that one never, ever should ask. - dlavery [more]
Unread 18-02-2010, 20:14
nekng's Avatar
nekng nekng is offline
Former 1836 Captain
AKA: Nate
FRC #1836 (MilkenKnights)
Rookie Year: 2007
nekng is on a distinguished road
No camera feed
I have spent some time trying to get the camera feed to the netbook to work. I have tried the 2010ImageDemo example code as well as my own code (see below). I am fairly sure that the camera is set up correctly because it worked last year, I can access it from it's web interface and I can successfully run the camera set up tool when I plug the camera into the classmate netbook. Does any one have any ideas as to what we need to do to make it work?
Code:
#include "WPILib.h"
#include "Target.h"
#include "DashboardDataSender.h"
 *2010 code
class RobotDemo : public SimpleRobot
	Joystick leftStick;
	Joystick rightStick;
	Victor right1;
	Victor right2;
	Victor left1;
	Victor left2;
	Victor bigmotor;
	Victor babymotor;
	int loop;
	DashboardDataSender *dds;
public:
	RobotDemo():
		leftStick(1),
		rightStick(2),
		right1(2),
		right2(1),
		left1(4),
		left2(3),
		bigmotor(5),
		babymotor(6),
		loop(0)
		dds = new DashboardDataSender();
		GetWatchdog().SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous(void)
		GetWatchdog().SetEnabled(true);
		GetWatchdog().SetExpiration(1.0);
	 * Runs the motors with tank steering.
	void OperatorControl(void)
		// Create and set up a camera instance. first wait for the camera to start
				// if the robot was just powered on. This gives the camera time to boot.
				printf("Getting camera instance\n");
				AxisCamera &camera = AxisCamera::GetInstance();
				printf("Setting camera parameters\n");
				camera.WriteResolution(AxisCamera::kResolution_320x240);
				camera.WriteCompression(20);
				camera.WriteBrightness(0);
		while (IsOperatorControl())
			GetWatchdog().Feed();
	//		HSLImage *image = camera.GetImage();
			right1.Set(rightStick.GetY());
			right2.Set(rightStick.GetY());
			left1.Set(-leftStick.GetY());
			left2.Set(-leftStick.GetY());
			if (leftStick.GetRawButton(1)==1)
							bigmotor.Set(1.0);
						else
							bigmotor.Set(0.0);
						if (rightStick.GetRawButton(1)==1)
							babymotor.Set(0.3);
						else
			               babymotor.Set(0.0);
			loop++;
			printf("Loop: %d", loop);
			dds->sendIOPortData();
			Wait(.005);				// wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
Unread 19-02-2010, 15:02
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: No camera feed
do you have v20 on the cRIO?
do you have WPILib 4.3?
did you run the Camera config tool?
are you using a crossover cable from port 2 on the cRIO to the cam?
is the camera's status ring green?
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 19-02-2010, 17:20
nekng's Avatar
Former 1836 Captain
AKA: Nate
Rookie Year: 2007
Re: No camera feed
Yes to all of your questions.
Unread 19-02-2010, 18:30
byteit101's Avatar
Re: No camera feed
are there any firewalls on the network or computer?
did you update the dashboard to 1.1?
do you have the local dashboard option checked under setup?
have you tried installing dashboard update 1.1 on a different computer with remote dashboard selected under Driverstation setup, and correct IP?
try this code:
Code:
#include "WPILib.h"
	AxisCamera &cam;
public:
	RobotDemo():cam(AxisCamera::GetInstance())
	void Autonomous()
	void Operator Control()
Watchdog.Kill();
Unread 19-02-2010, 20:15
misko misko is offline
FRC #0852
misko is an unknown quantity at this point
Re: No camera feed
What accounts are configured on your camera, and what permissions for each account? i.e. in Setup on the camera, select Users, what is the output?
Do you have a user FRC?
Issues with Classmate Camera Feed eovnu87435ds Programming 17 12-02-2010 22:29
2010 FRC Camera Live Feed Lag ideasrule Programming 23 11-02-2010 02:33
Still no camera feed cappielloa Programming 15 26-01-2010 21:54
Live Feed with Axis Camera CHSboy Programming 6 24-03-2009 14:43
Drivers' Station Camera Feed dhawk085 Technical Discussion 4 25-01-2009 19:12
