Go to Post FIRST has always been less than just a school activity for me and more of a way of everyday life. - Amanda Morrison [more]
Unread 18-02-2010, 21:07
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
File Handling
How would I read/write from a file in Java? It seems that FRC has omitted the Scanner and the FileOutputStream classes, the only ways I know how to do file io.
Thanks in advance
Unread 19-02-2010, 20:47
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Arrow Re: File Handling
Look at the javadocs for the following classes:
com.sun.squawk.microedition.io.FileConnection
javax.microedition.io.Connector
java.io.DataOutputStream
java.io.DataInputStream
For example, to create an output file on the cRIO:
DataOutputStream theFile;
FileConnection fc;
try {
fc = (FileConnection)Connector.open("file:///output.txt", Connector.WRITE);
fc.create();
theFile = fc.openDataOutputStream();
} catch (Exception e) {
You can then use the writeXXX() methods in DataOutputStream to write to the file. Be sure to flush() also.
- Ron
Team #2607 controls mentor
carmen ball handling falconmaster General Forum 14 30-01-2009 10:50
How to use the data obtain in one C file to another C file? tommy_chai Programming 8 11-01-2008 02:17
Didn't Like Digital Handling Anime-niac_2.9 Programming 1 05-02-2007 13:46
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
A New Method of Handling Nationals archiver 2001 9 24-06-2002 03:30
