Go to Post Heck, every human being has the potential to change the world, as long as the world still exists. - [more]
Unread 18-02-2010, 21:10
dan_h dan_h is offline
EE Grad Student
AKA: Dan Huizenga
#0518
dan_h is an unknown quantity at this point
Help! Can't get PWMs to work...
I'm trying to get our control system working, and everything seems to be communicating properly (diagnostics shows communication, robot code, stop button, left stick, enet link, ds radio, bridge, and robot as all green), and when I enable the robot in teleop the RSI light switchs to long on/ short off, however, output to the PWMs doesn't seem to be working. Our robot code is as follows:
Code:
#include "WPILib.h"
class DefaultRobot : public SimpleRobot
	RobotDrive *myRobot;			// robot drive system
	Joystick *rightStick;			// joystick 1 (arcade stick or right tank stick)
	DriverStation *ds;				// driver station object
public:
	 * Constructor for this robot subclass.
	 * Create an instance of a RobotDrive with left and right motors plugged into PWM
	 * ports 1 and 2 on the first digital module.
	DefaultRobot(void)
		ds = DriverStation::GetInstance();
		myRobot = new RobotDrive(1, 2, 3, 4);	// create robot drive base
		rightStick = new Joystick(1);			// create the joysticks
		//Update the motors at least every 100ms.
		GetWatchdog().SetExpiration(100);
	 * Drive left & right motors for 2 seconds, enabled by a jumper (jumper
	 * must be in for autonomous to operate).
	void Autonomous(void)
		GetWatchdog().SetEnabled(false);
		myRobot->Drive(0.5, 0.0);			// drive forwards half speed
		Wait(2000);							//    for 2 seconds
		myRobot->Drive(0.0, 0.0);			// stop robot
		GetWatchdog().SetEnabled(true);
	void OperatorControl(void)
		Jaguar temp(5);
		temp.Set(1.0); /* Expect, at the least, to see PWM5 on slot 4 move */
		while (IsOperatorControl())
			GetWatchdog().Feed();
			myRobot->ArcadeDrive(rightStick);  // drive with arcade style (use right stick)
START_ROBOT_CLASS(DefaultRobot);
At the very least, I would expect to see PWM5 move. I also tried adding a printf to show the location of the joystick Y axis (through the target console in the debugger), and it updated as expected. Any help would be greatly appreciated!
Team 518 Home Page
Unread 19-02-2010, 12:24
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Help! Can't get PWMs to work...
Do you have 12V wired into the sidecar through the WAGO connector? are all three lights at the bottom of the sidecar on, is the sidecar connected to the DIO module in slot 4 on your cRIO?
Unread 19-02-2010, 20:54
EE Grad Student
AKA: Dan Huizenga
#0518
12V -> Yes, lights -> On, Sidecar connected to slot 4 -> Yes
In addition, the expected pattern blinks on the RSI light.
Interestingly, the dashboard shows now change in the PWM output level, which leads me to believe that it's probably not a connection problem, and more likely a software problem ... it's just that I can't find anything that's out of place. I'm going to try formatting and reflashing the cRio tomorrow, because I'm out of ideas.
Team 518 Home Page
Can't get program to execute Thxe C/C++ 3 09-02-2009 08:33
CANT GET THE CANERA CODE TO WORK!!!! plz HELP!! its da PAT!!! Programming 3 18-02-2007 23:07
Can't get EDU RC to print things. devicenull Programming 2 29-01-2006 16:42
can't get R/C controller to work with EDUbot sweet-chan Robotics Education and Curriculum 2 04-03-2005 01:35
Why can't we get along? Sean_330 General Forum 23 19-03-2003 21:38
