Go to Post Pros of living in California from a Canadian standpoint: FRC on-field glass doesn't occasionally have shoe marks on it - Edxu [more]
Unread 18-02-2010, 22:07
pauldemonkey pauldemonkey is offline
FRC #2941
pauldemonkey is an unknown quantity at this point
encoder motor control
We are trying to use the encoders provided in the kit to stop our kicker so it will stay within the bumper perimeter. We have the basic encoder example, we are just unsure how to stop the motor so the kicker is in regulation.
Unread 19-02-2010, 13:10
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: encoder motor control
It helps first, to know the limitations of the devices you are using.
An encoder, or for that matter, a limit switch, does not stop a motor. It tells the controller what it knows about the position of your kicker, but stopping it, especially when moving rapidly, is a mechanical issue.
Motors and moving mechanics tend to keep moving, even when told to stop, because of inertia.
To stop your motor in such a situation, you'd have to start stopping it well in advance to account for that overshoot. Even countering the motion by commanding it to reverse would take time. By the time you got that to work, there'd be no energy left to transfer to the ball.
What you need is a hard stop, a mechanical item, that limits the travel of your kicker. Then an encoder or switch can be used to tell the controller that it has reached the stop.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Encoder Motor Control Wicked NI LabVIEW 3 11-02-2009 18:21
Can any one help us with programing the encoder to control the motor by ticks? Must Be Drama NI LabVIEW 4 09-02-2009 20:54
Optical encoder for denso window motor? jaredtkatz Motors 0 04-02-2009 16:10
encoder vs. motor stephenthe1 Programming 55 06-01-2005 22:07
PID control loop/Encoder question Zee Programming 18 30-01-2004 23:14
