Go to Post So is this how cRIOs are made? - pSYeNCe [more]
Unread 19-02-2010, 13:52
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
Rookie Year: 2010
dotbran is on a distinguished road
Dashboard Won't Show Up!
I've modified the current dashboard to include an indicator for a sensor switch on our robot. When I run the executable in the Developer account, everything shows up fine, but when I log into Driver no Dashboard shows up at all. I overwrote the new Dashboard.exe in the original's location, so it isn't a location issue. I looked into the INI in the Shared Documents and saw the filepath was screwed up (it replaced a few letters with zeroes, and switched two letters). Every time I log onto Developer I change it, but after logging in and out of Driver the path is back to it's screwed-up state. Does anyone have a fix for this, or possibly a link to the original INI so I can troubleshoot before I decide to flash the DS?
Update: I replaced my new Dashboard with an unmodified new Dashboard project. This still did not work, so I think I may have narrowed it down to a Windows Firewall or INI issue.
Unread 20-02-2010, 11:14
Pi Fighter's Avatar
Pi Fighter Pi Fighter is offline
Insert Monty Python Reference Here
AKA: Trevor
FRC #1718 (Fighting Pi)
Pi Fighter has a spectacular aura aboutPi Fighter has a spectacular aura about
Re: Dashboard Won't Show Up!
I was just making a dashboard for our classmate, and at first, I had the same problem. I did change the file directory for the .ini file, and it worked. Were you using LabVIEW, or C++? I was using LabVIEW, but that shouldn't make a difference because it's a .exe. The only thing I can think of is if you saved the changes you made to .ini. I hope this helps.
Unread 20-02-2010, 11:26
While the DS is loaded, it keeps the path in memory. If you change the ini file, then the DS saves the file on exit, your changes will be overwritten.
Does this explain it?
Greg McKaskle
Unread 21-02-2010, 11:46
AKA: Brandon Olsen
FRC #3219 (TREAD)
Rookie Year: 2010
Somewhat. Thanks for the help.
After restoring the Classmate (I couldn't solve the INI problem), I've decided to stick with the default DS, because, after all, it's just one LED I was changing the size of.
Unread 21-02-2010, 15:51
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
I was having the same problem, changing the path in the.ini file and after the driver station runs it garbles the path up.
I went looking around, then found that the name of the item that specifies the path should be "DashboardCMD Line", not "DashboardCmdLine" like it was. Changing that fixed it.
Twitter Profile
How to get the camera to show images on the dashboard? whcirobotics NI LabVIEW 38 20-02-2010 11:55
Inventor help: Text won't show up RogerR Inventor 2 08-03-2007 10:24
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
2004 Dashboard Protocal vs 2005 Dashboard Protocal Kyle T Programming 4 14-03-2005 22:19
the FSK show (fork, spoon and knife show) Psalms(118:6) Rumor Mill 0 23-04-2004 08:33
