Go to Post Ahem......"where are the President's safety glasses???" - Travis Hoffman [more]
Unread 19-02-2010, 14:31
Ryutso Ryutso is offline
Modularity, modularity, modularity
AKA: Toby Cubbin
FRC #0108 (Sigmac@ts)
Rookie Year: 2010
Ryutso is an unknown quantity at this point
Compressor Valves
We have a compressor this year, but no valves. What kind of valves are we looking for?
The KOP checklist shows some kind of silver/metal looking valves screwed into the airholes. We don't have those. What are we looking for?
Unread 19-02-2010, 16:05
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Compressor Valves
Here is a link to the Pneumatics Manual. Much of what you need will have to be ordered (fittings, tubing, check valves, cylinders, etc). The kit of parts checklist has one 24 VDC double solenoid valve, a quick release valve, and a 120 or 125 psi relief valve, which should be tested for proper release according to a team update. Familiarize yourself with the contained info.
http://www.usfirst.org/uploadedFiles...%20Rev%20-.pdf
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
anybody know where to get some quick exaust valves or dump valves chmconkling Pneumatics 21 18-02-2010 18:31
Leaky Valves Mark Deutsch Pneumatics 9 16-02-2007 15:07
solenoid valves? brian1717 Pneumatics 2 07-01-2007 15:28
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Leak of FIRST Valves Andy Baker Rumor Mill 0 12-10-2001 23:20
